Results 1 to 10 of 17
Thread: D2a SLS shock options
    Mar 2022
    Aucland, NZ
    Hi guys,
    I'm looking at replacing all 4 shocks and the front springs on my 2003 D2a, has SLS and ACE, looking to use standard front springs with std travel TF or EFS shocks.
    With the standard LR shocks there is a specific option for SLS (RDP102363) - what is the difference to other standard shocks ?
    Will the TF or TFS shock work well with the SLS rear end ?
    I do mostly highway driving with the occasional dirt and forestry road, so looking at keeping things fairly tame and comfy.
    Any advice on this ?
    Apr 2010
    South Melbourne
    You just need to check open and closed shock lengths for compatibility.
    See thus thread: 2" SLS lift with Bilsteins Installed
    No idea about the brands you mention. Go Bilstein if you can afford them.
    darwin
    personally i would keep to the standard shocks,the ride is pretty good.and they are designed for the suspension.if it aint broke dont fix it.
    Darwin
    03 disco 2a td5
    93 tdi disco [gone to a better home]
    2003 d2a v8 retired hurt
    1988 k100rs bmw gone
    85 county izuzu [gone to a better home]
    69 series 2a [gone to a better home]
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    Mar 2022
    Aucland, NZ
    Thanks so far,
    the current shocks are well flogged out, will need to replace them for sure.
    Just wondering what the difference between the SLS specific and the non sls specific standard shocks might be,
    as the Terrafirma or OME or Bilstein or what have you don't have an option for SLS.
    Does anyone know ?
    Feb 2011
    Hobart, Tasmania, Australia
    I recall reading years ago, where someone had posted up pictures and measurements, that the SLS shocks are longer.
    A possible option is the standard height Bilstein front shocks with the +2" Bilstein rears.
    Apr 2010
    South Melbourne
    Yep that’s correct - see post #14 in this thread:
    You can also use Std height Konis but these are a softer ride and bottom out too easily compared to the Bilsteins which suit the d2 better.
    Quote Originally Posted by twr7cx View Post
    Ive had the std Bilsteins in mine since 2010, absolutely changed the way it drove on the road, the only thing i noticed is being gas with SLS the rebound would cause it top over slightly due to the gas pressure. Not a real issue but it just felt a bit weird coming out of a dipand having the rear end rise up.
    The Bilsteins are gassed to suit a coil spring, there's actually no version specific to the SLS and with the rolling design on an airbag it'll extend that little bit more with the help of the shock.
    My rears are due for replacement, ones leaking oil and has no gas left, pretty sure the other is missing a little gas to but it still rides beautifully if not a little spongy for my liking.
    Clyde also sports Bilsteins and EAS, these have been in since 1997 and still rock solid
    Mar 2011
    Balbarrup WA
    Re D2 shocks
    Quote Originally Posted by HermanZ View Post
    Thanks so far,
    Does anyone know ?
    Have just changed out air suspension for coils (with 50mm lift).
    Had to go with straight forward Lovells HD coil rather than progressive rate, due to limited supply.
    Fitted springs and left original shocks in just to see.
    The original shockers fitted on alright, but had nil travel and even a minor bump was jack-hammer result.
    I had a pair of new "Terra Firma" "all terrain" rear shocks there, so fitted them.
    Compared to original shocks the TF shocks were much bigger diameter, and about 30% more travel when extended, so that their sweet spot covered the range of the new springs.
    Ride is now very acceptable and no "hammer" on bumps.
    Would not stay with standard shocks, given the improvement in ride by fitting the larger shocks.
    May 2015
    Williamstown, Victoria
    The SLS damper is part number RPD102363
    The coil damper is part number RPD102333
    Have not found what the difference is as yet.
    Build date 11th Oct 2003
    LROCV #1410
    NE Victoria
    32.83 MB
    Quote Originally Posted by Bohica View Post
    Air and coil springs need quite different damping criteria.
    I don't understand it enough to know what the differences need to be.
    That said, most coils are a linear spring rate and air springs are a rising rate.
    I would guess the difference is in the damping rate.
    Any one know any more?
    This is were we need Rick 130 to chime in, or Bush65 back.
    Tony
