Results 1 to 10 of 27
Thread: A different approach to removing the A/C compressor?
    Jul 2013
    I'm going to be changing my A/C compressor soon (once the new one arrives). Having a look through LR's write up on how to remove it has me not at all that excited on doing the job. Looks bloody tight. Was having a think outside the box and was wondering if anyone has dropped the front diff out for easier access? I've seen some pics of the area with the front diff removed and access to the A/C compressor looks to be quite good that way - only issue I could see that may create an issue for removal is the trans cooler lines. Anyone got any thoughts?
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    Jun 2013
    Universe A
    Quote Originally Posted by shanegtr View Post
    Please share any secret shortcuts you find.
    It might save my marriage if I can provide cool air in the car!!!
    Dec 2009
    SW WA
    I just got mine changed this week, cost me $800 in labour plus $100 for de-re-gas and $600 for the compressor.
    I usually do most of my own spanner work but was more than happy to get this done by an Indi, SOO good to have aircon again!!
    Jun 2013
    Universe A
    Quote Originally Posted by kenl View Post
    That's incredibly cheap, quotes I've seen are around the $3k Mark.
    Good for you!
    Sep 2014
    Baldivis WA
    I will be checking with my indie, that sounds reasonable.
    Sep 2014
    Baldivis WA
    I will have a look under mine when I get the chance, should be possible, the transmission cooler lines are easy to disconnect, just means we'll need to plug them and top up the fluid after. They dropped my diff down when they changed the engine mounts, not that hard, but you do need to drain and refill it
    josh.huber Guest
    I'm not sure how different a D3 2.7 is from a D4 3.0. but I had it out very easily. Sure some bolts are a bit"exciting" to get out. But over all. Not a bad job.
    From memory, belt off, wheel off, inner guard off. Few turbo hoses off, pipes off, wires off, unbolt it. Go forward then down.
    I watched a couple videos you have done Shane, it's childs Play for you,
    Ratchet spanners with flex heads, great 3/8 drive it with extensions and wobbles.
    Fun fact. I spent hours trying to find the drier, the longest part of my job was finding and changing the drier! The paint job on it was amazing
    Mar 2016
    Quote Originally Posted by josh.huber View Post
    You’re going to keep us in suspense as to where the dryer is?
    2007 Audi RS4 (B7)
    Oct 2012
    Is $600 locally bought compressor price?
    Jul 2013
    Quote Originally Posted by Eric SDV6SE View Post
    Certainly looks like it could come out easier with the diff gone, however I think I would still need to remove turbo and coolant pipework down the side to access the compressor bolts so it may not be worth the effort.
    Im sure it will be fairly straight forward, just looking for possible options where access may be easier as I hate working in the tight corners of the car.
    Shane
