Did it throw up a code? If so you may need to clear that first, plus I'd be checking the fuse box...
Hi All,
I think I may have caused an issue with my LH LED Brake light. I had it unplugged and the brakes applied when I touched the pin in the socket. It gave a flash but now LH Brake light doesnt work. RH one and Tail gate one are OK.
Any advice appreciated.
Johnny Ruch
Checked fuse 25 and that was OK. I have no way of checking codes at this stage. I have just re-read my post and I missed the bit where I was using an LED test probe when I touched the brake light pin, It was the test probe that gave a single flash, and when tail light unit plugged back in there was no brake light.
Johnny Ruch
