Results 1 to 10 of 14
Thread: Trailer icon
    Feb 2022
    ACT
    Trailer icon
    I have a MY10 RRS TDV6. As I understand it, when a trailer is connected, there should be a trailer icon that appears on the dashboard.
    When i recently connected a borrowed box trailer, the connnector(we'll call this 1) that came with the car didn't work( brake and tail lights ok, right indicator stays on). My friend(he is an old Italian, I thnk he never throws away anything!) happened to have a connector(we'll call this 2) that worked, so was happy with that.
    However, I tried connecting our caravan and neither connector works. 1 is the same as before, tail lights and brake lights work, but right indicator stays on, even when the indicator is off in the car). 2 doesnt have any indicators at all.
    Both trailer and caravan have LED tail lights. Could this be the root of the issue?
    I am getting an auto electrician to look at it next week, but just wanted to get some thoughts first. Could it be that despite having the right mechanical connectors, the trailer option is not activated on the CCF? I have a GAP iidTool on order, but it doesnt get here until Wednesday.
    Also, is it normal to have a bit of play in the tow hitch? It drives me nuts, and i'm hoping it's an easy fix.
    Thanks for your help.
    Feb 2009
    The first guess would just be the LEDs not drawing enough current.
    Not sure re the connector issues (you mean flat to round 7 pin?)
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    Feb 2022
    ACT
    Yes sorry, so the original Euro type round to 7 pin flat. I should also mention that I use an elecbrake controller that has a 7 pin flat (from the caravan) to a 7 pin flat (on the RRS connector)
    NSW SW Slopes
    If the car hasn't had an electric brake controller used with it before then the wiring to the trailer socket will still be incorrect for Australian wiring. Originally the pin that supplies our brake controller signal (pin 5 IIRC) is wired to supply one side tail light whereas our trailer tail-lights are all powered from a single wire. You will need to check for power at the pins in the socket to confirm the state of the wiring. If the wiring is original then the usual solution is to cut the wire in the trailer harness behind the left light cluster after the join of the left and right wires then use the cut wire for the brake controller.
    Feb 2022
    ACT
    Hmm, I might have to get a multimeter i think just to see what’s coming through on the pins.
    The elecbrake app has a function to see what voltage is coming through the device, and it shows 14.7v on both the tail and brake light circuit.
    I’m going to the Queanbeyan 4x4 show tomorrow, so will hopefully pick up a multimeter there, along with a handheld UHF and towing mirrors.
    Feb 2022
    ACT
    LOL!!!
    So I'm starting to realise that if theres a way to make something complicated, LR will find it. I actually looked at the two connectors I have to see how they're wired, and realised that they are not 13pin to 7 pin convertors - one is a 5 pin round and the other is 7 pin round (the 5 pin came with the car, the 7 pin in the one that my mate had).
    So what now?! I then looked at the connectors on the car - yes they are both 7 pin round! ARGH!!!
    I will get a multimeter and measure everything.
    Feb 2022
    ACT
    Hah! Now i feel a little stupid, just picked up that instead of the euro 13pin plug it has a 12N and 12S plug - argh!! And i thought i had read all the posts on trailer wiring.
    Jul 2020
    Urila
    Once you have the wiring sorted out ... with incandescent bulbs in the trailer the trailer icon will appear on the dash when either turning indicator is on but with LED trailer lights the trailer icon will not appear and the trailer indicators will flash too fast. There are gadgets you can buy to plug into the car trailer socket and have the trailer plug into that which will make the trailer icon appear and the flashing be normal. Or wire in a load resistor yourself, just make sure it is not powered on all the time. When the car detects a trailer is plugged in (ie the trailer icon works) I think the car adjusts ABS and stability control.
    Feb 2022
    ACT
    Curiouser and curiouser!!
    So I went to a mates place yesterday and hooked up to his caravan that has incandescent bulbs - hey presto all works! Trailer icon flashes the lot.
    So i may have two issues -
    1) LED taillights causing problems
    2) Elecbrakes causing problems
    I will be getting some load resistors this afternoon so will wire them in and see how it goes.
    Apr 2012
    Whyalla, SA
    You have an external electric braking system or one wired into the vehicle eg. Redarc?
    I'm pretty sure I know what the problems going to be.. And it has nothing to do with LED or Incandesent... thats an entirely different issue.
