Why would you post this in the 'Ask A Moderator' section - why not try the RRS L320 section?
 Member
						Member
						Hi does anyone know where to get oem quality headlight lenses for my 2012 RR SPORT?
I have found them on headlight-headlamp for us $240 shipped including glue. Has anyone got these or the ones from bimmerjakes?
 Fossicker
						Supporter
						Fossicker
						SupporterpowerfulUK sell some for pre and post 2010 L320s.
no idea, but mine came up well from a headlight restore kit (basically very fine wet dry) though i did have to start with some 2000 grit as the supplied 4 grits were not coarse enough, also i used a buffing pad on end of drill for final step, which gave a much better finish than when i tried by hand.
 Member
						Member
						 Member
						Member
						How do you post a thread?
Please explain?
Try researching a little before you post - you could have asked the moderators where to post but instead you just posted where you did.
Call people a dickhead here and you will get sent to the sin bin in real short order - not going to report this time because you are new.Read the rules.
 Member
						Subscriber
						Member
						SubscriberI have 2010 L320 and found some on aliexpress. They fit well but a bit of a pain getting the headlight to seperate.
https://www.aliexpress.com/item/1005...d=3kESnZzhKO5D
 Master
						Master
						Be careful getting them overseas - are the lenses sided? If they are, then powerful UK would probably be the best bet if they have them. Or maybe try a wrecker like Triumph Rover at Lonsdale in South Australia.
2012 L320 Range Rover Sport Fuji White
REMLR 012
No 5 Trailer ARN 177-295
2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
SOLD Engineers Trailer - no id
SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
SOLD 4MP COY Series 3 FFR 30-209
