Results 1 to 2 of 2
Thread: VW Diesel engine problems
    Nov 2008
    Knaresborough North Yorkshire UK
    Looking for any suggestions on where to turn next
    Neighbour has Skoda Octavia which once you drive for about 10 minutes overheats. Idles in driveway fine
    Have replaced the water pump and thermostat. Checked hoses for any that might be soft. Used garden hose to flush water through block with hoses off and all runs fine. Also same through the radiator
    No sign of any deposits on oil filler cap and oil appears OK
    Where to look next?
    NSW SW Slopes
    Using a hose to run water through a radiator won't reveal blocked tubes unless almost entirely blocked.
