Results 1 to 10 of 11
Thread: 'Plastics' declining Quality
    Gosnells
    First noticed this years ago, the 'rubbery' coating on a favourite binocular was... becoming sticky...followed by a favourite pair of Ooooor workboots going the same way. - Urethane sole losing layers and sticking to smoooth surfaces like tiles. SWMBO was unimpressed.
    Years later two pairs of dress shoes - minimal use - dry-cracked across sole/midstep
    Long story shrt,
    --- Bootmaker informs the phenomena is now "common", and suddenly started +10 years ago, mens and ladies shoes (soles mainly)
    His theory is the "base" polyurethane which is made in You Know Where, has been programmed to decompose ... Based on "speed of onset" and continuation.
    ( Very like Flu from Wuhan... also loses strength with time... )
    F/Forward to now. Wife's Magna developed a coolant leak around heater. PAX carpet soaked. Two bottles of RISLONE slowed it right down, now "no" great loss of water, but...
    Turns out, BOTH the "plastic" fittings - matrix - through - firewall were cracked. Plastic gone rotten, brittle, obviously cracked and both snapped off when hoses disturbed... broken surfaces look 'granular' supporting "Decomposition" theory, as opposed to excess lateral load.
    We'll be seeing more of this, many other cars use this design approach..
    Nov 2008
    Knaresborough North Yorkshire UK
    Manufacturers consider a car has an 8 year life so if the plastic goes at 10 years they probably consider it was not a problem as is beyond expectations. Now their expectations and yours may not in this instance coincide
    Jan 2017
    Geraldton WA
    Plastic that degrades rapidly is a bad idea for shoes But it is a Great idea for the enviroment.
    Using plastics and quality in the same sentance is an oxymoron.
    4.6m Quintrex boat
    Narre Warren South
    I've had the same with binoculars and other items, sometimes trying different solvents you can remove the sticky surface.
    Shoes/boots with polymer soles seem to have a very finite life. I had a pair of Redbacks that I hadn't used for years, wore them one day and the soles crumbled & fell off.
    I now tend to get boots from the Blundstone Outlet Shop so at least I'm only paying about $55 per pair !
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    thats one of the reasons you pay more for RM Williams boots.
    my feet spread the wrong way for RM Williams boots and after a long search to find the right boot for me I ended up at Rivers and walked out in new pair of their boots with a warranty similar to RM Williams. the sole is stitchdown , very soft , very comfortable , so you can get quality from Rivers. They are now around 7-8yo still look perfect.....dubbined them this morning.
    After having several soles fall off what appear to be good shoes I now buy stitchdown on all shoes, even my "good" leather thongs are stitchdown.
    Try to avoid plastic anything.
    Oct 2008
    Cloncurry NWQ
    Quote Originally Posted by ramblingboy42 View Post
    Is that your "Formal" thongs, good "Going Out" thongs, "Yard" thongs or "Just Dagging to the Shops" thongs?
    Sep 2012
    Westlake ,brisbane
    When we had our Engineering business we supplied our workers with two pair of steel cap boots a year , some of the guys didn't need them straight away so would put in the cupboard until needed , problem was when they did start wearing them the soles would fall off with in a couple of days . The Rep from the clothing supplier told us the boots needed to be worn straight away so the soles would flex or they would brake up.
    As for Car upholstery it has to start braking down with in 7 years . Our Citroen C4 the foam started disintegrating after 2 years , every time I vacuumed the car I would find powdered foam grit under the front seats , We got rid of after 4 years & don't think the seats would have lasted 7 years.
    Denmark WA
    Unhappy
    Quote Originally Posted by superquag View Post
    Long story shrt,
    Interesting. Back in the ‘90s at Uni we had a design teacher who told us he’d been required to help design a compost tumbler, like the old Sunbeam ones. They proudly showed the manufacturer a design using a plastic that would last decades, like the old ones did. They were then promptly instructed to incorporate an enzyme in the plastic to ensure it broke down, “even in the shade”, within from memory 5 or 8 years (studies showed that’s what people accepted as ‘good quality’). Likely that is 2 or 3 years now!
    Every noticed how toys and lampshades from the ‘70s are maybe faded if left in the sun but seem pliable and fine? Hmmm. Yet where are those late ‘80s onwards items??
    Oh! I’m sure it’s all done to save the environment! “Biodegradable”!. If only this were the true motivation!!!
    1974 Military Lightweight Landy --- Some dementia at 50 years old
    2000 Disco series 2 now sadly moved on!
    No5 Trailer joined the fold... Awaiting graduation to road licensed!
    2021 Mazda BT50 or is that DMax?
    Jun 2008
    formals.....my daggy's are really old surfer joes......and I need a new pair
    Gosnells
    Quote Originally Posted by 1950landy View Post
    Around 1979 I had a '74 VW Passat. Similar, dashboard skin dry and cracked, foam underneath it decomposing, back seat top section replaced by Original Importer..... Many would crack during the voyage from Germany !!!
    - Front seats foam also going off (replaced driver's seat with a Renault 16 seat. Pure luxury, and soft vinyl.
    Poured foam underfelt (carpet) also in "interesting" state... Plastic radiator overflow tank also... dead. - like the plastic tank on Lady Sarah, '95 Classic. Neesless to say, the plastic radiator tanks gave way in Passat... Replaced with copper one.
    * Bootmaker mentioned that keeping those boots or shoes inside, in UNventilated places would hasten decompostion, over shoes left outside...
