Results 1 to 9 of 9
Thread: Are D1 & D2 roof lines the same?
    shayne86 Guest
    Hi guys.
    Can anyone on here confirm that the roof line and gutters are the same dimensions between a d1 and a d2?
    I've seen a roof rack from a d1 at the wreckers that would look awesome on my d2.
    Sep 2018
    Travancore
    D2 has a slightly longer roof but the width between the gutters is the same - had an ARB half rack on the D1 which transferred directly to the D2. The front roof mounted rails have a differences, profiles I believe, could be wrong on that
    2004 Discovery 2a TD5 Auto Aspen Green AKA Robin
    2000 Discovery 2 TD5 Auto Alverston Red AKA Edward
    1997 Discovery 1 TDi Manual White - Gone but not forgotten
    1994 Discovery 1 V8 Auto - Gone once it consumed half the worlds resource of oil
    shayne86 Guest
    Cheers mate. I reckon it's almost worth the gamble
    99.87 MB
    Yep, the D2 should be about 150mm longer in the rear section.
    Funnily enough, my rack is actually a Defender roof rack on Discovery legs.
    Slunnie
    shayne86 Guest
    Thanks everyone. I always assumed they were fairly close but always good to ask those in the know Are D1 & D2 roof lines the same?
    Avoca Beach
    That looks like a Baja Rack.
    I was sales manager for a while until the importer then went belly up.
    Be aware that there is no adjustment on the legs , but Discos are all different so you must ensure that the legs are shimmed so that there is equal pressure on all legs. or the rack will break.
    BTW a D1 rack will fit a D2 but not Vice Versa
    Regards PhilipA
    shayne86 Guest
    Regards PhilipA
    Thanks for that! This is why i love this forum Are D1 & D2 roof lines the same?Are D1 & D2 roof lines the same?
    shayne86 Guest
    Sadly it appears the roof rack has sold. Thanks everyone for the info regardless, its greatly appreciated Are D1 & D2 roof lines the same?
    Jagspeed Guest
    Regards PhilipA
    Actually, I've seen a couple of D1's here in the States that had D2 racks on them. The D2 rack is longer, so it sticks out off the end and looks goofy, but it does fit, sort of...
