Results 1 to 10 of 13
Thread: Series 3 stage 1 gearbox conversion
    Apr 2022
    Could anyone recommend what would be the best 5 speed gearbox to install on the series 3 stage 1 landrover to replace the LT95, would it drop the revs much at 100kph.
    Also, has anyone done the power steer conversion and is it a big job, can anyone recommend a company to buy the power steer kit from? Cheers, Scotty
    May 2006
    Woolgoolga
    First up, whats your budget?
    Choices that are available that i'm aware of are,
    R380
    Isuzu MSA/MXA
    Tremec tr4050
    Quote Originally Posted by Vern View Post
    R380
    Isuzu MSA/MXA
    Tremec tr4050
    Also from the LR stable - LT77 and LT85.
    May 2006
    Woolgoolga
    Quote Originally Posted by 101RRS View Post
    Lt77 not behind a 4bd1 though.
    Lt85 yes, but why of whySeries 3 stage 1 gearbox conversion
    Well the mistake both of us made was firstly not asking the OP what engine were we talking about .
    You assumed diesel - I assumed V8 . The fact he wants revs reduced at 100kph indicates a V8 to me.
    Of course the OP should have made that clear.
    May 2006
    Woolgoolga
    No mistake on my behalf, I know he has an isuzu from another post he made. Series 3 stage 1 gearbox conversion
    Thats cheating - you can only respond to the information provided in the thread.
    Apr 2022
    Gearbox mods and power steer for stage 1.
    Sorry Guys, i should have mentioned in my original post that the stage 1 I have got is the Isuzu 4BD1 motor with the 4 speed box. I am trying to find the strongest 5 speed box that I can get to go behind that motor to drop the revs down substantially when it is sitting on a 100kph as it is screaming its lungs out and is as noisy as…
    Also, has anyone done a power steer conversion to one of these and what company did you use. The only good thing is i don’t need to go to the gym after taking it for a drive :-). Cheers, Scotty
    Evelyn, Atherton Tablelands
    [QUOTE=Scozzzy;3146351]Sorry Guys, i should have mentioned in my original post that the stage 1 I have got is the Isuzu 4BD1 motor with the 4 speed box. I am trying to find the strongest 5 speed box that I can get to go behind that motor to drop the revs down substantially when it is sitting on a 100kph as it is screaming its lungs out and is as noisy as…
    At the risk of asking a stupid question - are you sure that your LT95 box has the Isuzu High range gears? It sounds like you may have the lower transfer case ratio from a V8? Is it possible that the box has been swapped in from a V8 at some stage?
    Apologies if you've checked this possibility, but the description of the engine 'screaming' sounds strange.
    Michael
    110 300tdi (1999)
    110 V8 County (1984)
    SIII 'Game' (1977)
    Perth, WA
    I've got a Stage One V8, and have looked at fitting a R380/LT230 and LT85/LT230, neither will fit without modifying the seatbox and floor. The R380 is too tall in the back and hits the seat box, the LT230 hi/low casing hits the floor/seatbox.
    The output flanges of the LT230 are fairly close to where they are with the LT95, within 25mm from my quick measurements.
    Hope this helps,
    Tim
    R380/LT230 on the left, LT95 on the right.
