Hi Prelude, first off, a lithium battery will NOT damage your alternator.
Next, because you have a vehicle with a SMART alternator, you will not be able to charge the lithium battery directly from the alternator. You MUST use a DC/DC charger, and this must be matched to the lithium battery’s maximum continuous charge current.
If you try to charge the lithium battery directly from the alternator, your lithium battery will not get charged much over 20% capacity and even if you fully charge the lithium battery with a battery charger before you go for a drive, when you go for a drive, you will continuously discharge the lithium battery.
Beginning a trip with a fully charged 100Ah lithium battery, after just 2 hours of driving, your lithium battery will have been discharged down to around 20%.
