On the steering relay free play, make sure that the play is not from the bottom of the relay moving. It is supposed to be securely located by a bolted on ring that is a close fit on the bottom cover of the relay. Also, if the arms are allowed to move on the splines the splines will wear, and I have had an arm break, probably due to movement on the spline.
