Results 1 to 3 of 3
Thread: Subtle surge
    Oct 2017
    Phillip Island
    Subtle surge
    Hi all,
    Just noticed a very subtle surge when under constant throttle. If it were a petrol I would suspect a dodgy lead. Not sure if its a possible injector problem, it still pulls like a train. Interestingly it cranks for about 3 seconds before it fires as well. My son's 4bd1 fires instantly. Any thoughts/theories.
    Mark
    Nov 2007
    Townsville Nth Qld
    I have a similar issue with mine. Only at idle, every now and then it will pickup slightly and after a minute or two drop back down. My ride is a converted 300 tdi to 4bd1/T . Mine pulls like a train no excessive smoke or and other noticeable issues.
    As for the start issue mine does the same. Sometimes it starts straight up and other times a second or two on the starter. I put both issues down to Henry the 130 being an individual. I would not be concerned as long as you keep the fuel servicing up to date. Fuel filter and drain the oft forgotten fuel separator. I also check the mesh strainer under the injector pump annually. Baz
    Oct 2017
    Phillip Island
    Quote Originally Posted by Bazzle218 View Post
    Cheers, funny you mention the idle pickup and then fall, this engine is doing the same whereas the previous 4bd1 I had in the car didnt do that. I did have a sedimenter clog up and forgot to check the strainer. Thats a good point...
