@cambo will hopefully be along to advise.
Hi all
This one is doing my head in
2012 D4 TDV6
Harmon Kardon (not logic 7)
With the large screen
Everything was working fine and then one day - no bass or lower mid range sound
The Subwoofer still works but everything else sounds tinny
Action so far
Via wreckers
Have replaced
- the Head unit
-And AMP(in the rear of car)
-the MOST channel looks to be working
-It doesn’t matter where I put the fade/balance same ****ty sound regardless of speaker
The questions on my mind are
1. Is there some other device the processes the audio between the AMP and Speakers
2. are the speakers to blame (if so how to 4 or so speakers all go at once?)
3. I haven’t replaced the screen unit - but surely that doesn’t process the sound?
What am I missing
Need my tunes
Help??!
Ps anyone want to buy a spare head unit or amp
Foz
 TopicToaster
						Subscriber
						TopicToaster
						Subscriber@cambo will hopefully be along to advise.
2007 Audi RS4 (B7)
Actually bit of an update
In terms of sound it’s sort of sounds like poor Mono
I dunno grrrr
Help anyone ??
Patience... You could message "Old Jaguar" on FB or Cambo on here.
Not everyone reads everything daily or hourly!
What input are you using? Same problem on all sources?
I've had ****ty sound in the past myself - turned out to be a loose headphone jack on the Aux input...
2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
Hi Veebs
All sources
CD
BLUETOOTH
RADIO
very frustrating
Have you checked the fuses in the car?
I don't have a 2012, or even my own D4 to check, but I would start with:
Fuse 2 in the upper compartment (behind the glovebox) - should be a 10A
and Fuses 41, 64, 67 and 68 in the lower compartment
Fuse Box Diagram Land Rover Discovery 4 / LR4 (2009-2016)
