Could you let us know what kind of situation you are in where this is needed?
You could try "Sand" mode with the DSC still on and the gear lever in Command Shift and change gears manually. Otherwise the engine likes to rev its tits off in Sand mode.
But if you are in sand you want that DSC turned off or it will bog you pretty quickly.
				04 L322 Vogue V8 - Work truck
07 Freelander 2 TD4 SE - The wifes
74 Leyland P76 Targa Florio - Aspen Green
91 Kawasaki GPZ900R
Previous LRs  = 78IIa series - 81, 93, 95 RRC - D2V8
