Results 1 to 10 of 22
Thread: Van refurb
    Jan 2017
    Geraldton WA
    Van refurb
    We have been refurbishing an old pop up van over the last few weeks and I had one look at the annex with all the poles, barwork, ropes canvas and the other stuff and decided stuff that for a joke and fitted an elcheapo Kings 2.5 x 2.5 awning.
    A few minutes to set up instead of hours of hard yakka screwing about with the original annex
    4.6m Quintrex boat
    Mar 2012
    Armstrong Creek, Qld
    Our van annex has lived in a cupboard since we got the van. I still have the roll out awning attached. An annex is probably OK for permanents or something more than a month's stay.
    A waste of space and time otherwise, I reckon.
    Have you attached the awning to the van wall and not the roof? Easier to reach, ay.
    'sit bonum tempora volvunt'
    Jan 2017
    Geraldton WA
    Quote Originally Posted by Saitch View Post
    Yep attached to the wall, It would be too high hooked up to the pop up roof .
    It is at the same height as the original annex
    4.6m Quintrex boat
    Mar 2018
    Perth (near Malaga)
    Horses for courses I suppose. We use my grandfathers van with his original full annexe. Once the van is chocked and leveled, it takes us about 20 minutes to put the full annexe up. Getting it down doesn't take much longer except if it's wet, then a bit of extra wiping required.
    It's whatever you're used to I suppose.
    Nice job with the awning. Got a pic of it out?
    Jan 2017
    Geraldton WA
    Quote Originally Posted by BradC View Post
    Our first van an antiquated Jaco dove had a full awning and it was an absolute nightmare to errect, The one with this van is verry simmilar.
    I had a full annex on the last van and Never used it in the 6 years that we had it, We did however always use the roll out awning.
    I have had awnings on the last 4x 4WD's and they usually take 3-5 min to errect and peg down, The one on the van will be no different
    I also still have a couple of awning extensions if I feel the need to close in or extend the awning which are fast and easy to add as well
    When I fitted the awning to the van I screwed and glued (Sikoflex 252) a backing plate of 10mm PVC to the van and then screwed the awning to that and as I only did it this morning I want to let the sikoflex cure properly before deploying the awning, I will post images in a couple of days of it set up
    By using this type of awning I have shaved off better than 50kg in poles and tarps and emptied out the front hatch which is quite a bit of a saving on a piddly little 14f van.
    4.6m Quintrex boat
    St Helena,Melbourne
    4.28 MB
    Our recently acquired van has a roll out awning and full annex, leaps ahead of the old style sail track annex of my parents van.
    I set it up in the front yard and it takes hardly any time.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jan 2017
    Geraldton WA
    The awning on our Jaco expanda was electric Push a switch and it depolyed, I Do miss it as it was effortless to use.
    The solar panels have finally arrived and I will install and wire them up this afternoon or tomorrow and I will be able to do a real time test running the 140l 240v fridge via the inverter.
    I ran it for a couple of days with a charger hooked up to the batteries set at 6A and it maintained the batteries at 100% SOC So hopefully the 2x 250w panels will add enough power during the day to run this 24/7 without depleating the batteries too much overnight.
    I finished sanding back the floor of the van, painted it and used those vinyl woodgrain tiles to replace the crappy lino flooring.
    Still a fair bit of work to do yet as it is a 1978 vintage van and it is showing its age a bit But it is coming along nicely so far
    4.6m Quintrex boat
    May 2003
    On The Road
    Our 23' van came with 6 separate bags of canvas/annex.. we've tried to put it up once.. ( as did the original owners by the look of the canvas) but it was all too hard.. I'd probably save 100kgs by selling it and recoup 75% of the front tunnel bin...
    Mar 2017
    Our 18' van only has a roll out awning and no annexe. We've never felt the need for anything more. Even the awning is rarely deployed.
    Jan 2017
    Geraldton WA
    4.6m Quintrex boat
