Results 1 to 10 of 17
Thread: Caravan LPG warning SENSOR
    May 2003
    On The Road
    The manufacturer of our caravan stove has advised all SWIFT 500 series gas stoves to be turned off at the gas switch. While I dont want to blow us up,, I do need to keep using this stove.
    Can anyone recomend a LPG sensor? Help with tech reccomendations on the sensor? We have had no (abnormal Caravan LPG warning SENSOR) smells, so far. Its about fractures in aluminium lines??
    Two explosions in WA in the last two years...
    Mar 2018
    Perth (near Malaga)
    LPG sensors have been mandatory on boats for years, so we've been through a few. Most use a heated semiconductor hydrocarbon detector, so they draw a bit of 12V to keep running. As LPG is heavier than air and pools, just pick a location its likely to fall and stay and plop one or more there. On the boats we had them hooked up to a solenoid on the bottle so any trip of the sensor immediately cut the gas supply whilst letting us know in no uncertain terms it was going off (a demented canary through a megaphone sort of thing).
    Between the sensor and solenoid, it was nearly an amp continuous on the 12V.
    As for recommendations, they were all much of a muchness. Being mandatory on boats, there's stacks around.
    Back down the hill.
    Just leave the door open, the gas will escape.
    Sorry Pedro, I'll get me coat eh.
    May 2003
    On The Road
    Caravan LPG warning SENSORCaravan LPG warning SENSOR
    Back down the hill.
    Just look after Di, Pedro. We'd miss her.
    Jan 2017
    Geraldton WA
    Is it difficult to change out the crappy ally lines?
    4.6m Quintrex boat
    Brisbane,some of the time.
    You could cut a hole in the floor of the van,about 6" in diameter.
    Should do the trick no worries.
    It might save having to leave the door open.At least you could put some mesh over the hole to keep the snakes and spiders out,and then a door mat over it in the cold weather to stop the drafts.
    Aluminium gas lines................... who'd have thought.
    Quote Originally Posted by 350RRC View Post
    We had them in refrigeration once,for a short while as well,some have to learn the hard way.
    Blind Freddy could see they would be absolutely useless in our industry.
    Quote Originally Posted by BradC View Post
    LPG sensors have been mandatory on boats for years, so we've been through a few. Most use a heated semiconductor hydrocarbon detector, so they draw a bit of 12V to keep running. As LPG is heavier than air and pools, just pick a location its likely to fall and stay and plop one or more there. ...................
    So the gas pools down low, sensors need 12v and need to be put low?
    What could possibly go wrong with powered sensors detecting an inflammable gas in an enclosed environment I wonder?
    DL
