Door locking problem
Originally Posted by
Drafrete
Hi forum members,
I have an issue developed in my 2012 D4. The rear driver side door won't lock or unlock with the rest of the car. It looks like an electrical connection problem.
The initial symptom was the the door did not unlock with the rest of the car and stayed locked shut. it was not possible to manually unlock it from inside either. Thought it might have been an actuator failure so I took door panel off but failed to be able to move the lock so then took the car to my local indie who managed to get the door unlocked and open. But once put back together the door won't respond to the key or the lock button. We have replaced the rear passenger door actuator but the same issue persists. The door does now lock and unlock manually (from the inside), but won't respond electronically. So it looks like a communication issue.
I have connected the Gap tool and I get two door related error messages and I am hoping that someone might be able to recognised them and point me in the direction of the part of the system that may have a problem.
The errors are:
DDM - Driver Door B1A98-87 (2F) Local interconnection network bus circuit 1 - Bus signal message failure - missing a message
PDM - Passenger Door B1163-15 (6C) Left mirror heater output - general electrical failure - circuit short to battery or open
Are these likely to be related?
Any hints on where in the wiring I should start looking?
Thanks in advance.
I’m confused. One minute you say the drivers rear door and then the passenger rear door. Which is it and which did you fix?
So you’re saying your Indi gave up and couldn’t fix it?? Isn’t that their expertise- fixing cars?
Your errors seem to imply you might have a general wiring issue going into the door. Maybe pull back the harness where it goes between the body and the door and check for damaged wiring?
Re-reading you have errors for both. I am confused.
2007 Audi RS4 (B7)
