Results 1 to 10 of 16
Thread: Looking for P38 parts
    P38dan Guest
    Could I please ask you guys fro help, I am trying to purchase 4ea radiator to cooler bush, p/n ESR466, I strike out at every turn, I would settle for aftermarket if I could find some, any info or advice on where I might be able to purchase would be appreciated.
    bruceph Guest
    Hi,
    I know this is probably not much help, but the new part number for the ESR466 is PCG100370 ESR466 - Land Rover Bush-oil cooler to radiator mounting | Jaguar Land Rover Classic Parts
    Have you tried KarKraft - 9 Egerton Street Silverwater NSW 2128 (02) 9737 9944
    They have had some odd bits in stock I have found in the past.
    Hope that helps.
    Bruce
    I checked BMI and they didn’t have either part no.
    I don’t even know what it looks like to be able to make suggestions.
    P38dan Guest
    Hi bruceph and P38arover, thanks for the replies and greatly appreciate it, Yes I have the new part number and same issue with no stock anywhere, anyway on Monday I will be calling Karcraft and hope they have some or maybe more contacts, and yes every piece is information does help a lot, anyway again many thanks and my journey continues.
    When I go out to KLR on Tuesday, I'll get them to check if it available from their UK supplier.
    P38dan Guest
    Hi guys, I called KLR and Karcraft and struck out on both, seems that they have never had an inquiry about these mounts and therefore have never sold any, I will try a few more contacts in the UK but don't hold much hope, I purchased the P38 as an unfinished project and these mounts were and are missing so I don't even have an example, its a complete dilemma anyway thanks again for everyone's help and advice and my journey continues.
    Apr 2011
    Wandong,Victoria,Australia
    Quote Originally Posted by P38dan View Post
    Try British Car Components in Melbourne - 03 9329 5766
    I buy almost all of my LR parts there.
    88 Perentie FFR - Club Rego
    93 Discovery 1 200 Tdi - Club Rego
    03 130 Td5 Single Cab
    06 Discovery 3 Petrol
    22 Defender 90 - Full rego
    Jun 2020
    Rockhampton, central Queensland
    Hi Dan,
    when I had the motor out of my P38 I also replaced the condenser and fitted an alloy radiator. Those mounts were pretty much passed their use by date, to put it nicely. From memory I tried to get new ones but no luck so I went through a box of shock absorber rubbers at my mates workshop and I found enough rubbers to make it all fit together. I will look what I have left in the shed tomorrow that might help you out.
    Regards,
    Alan Temperley
    P38dan Guest
    OK guys thanks again, will check British car components tomorrow and if no luck will go to autobarn and try for some shockie rubbers, cheers.
    I had a look at the Allmakes site today and they could be available but the price was GBP11 each! (Genuine, not aftermarket.)
