Results 1 to 10 of 22
Thread: Alternator - to replace or not?
    Feb 2022
    QLD
    OK Folks, comments please:
    I am at 200k on the original alternator. It's still fine, but I have an OEM Denso replacement in the shed. Do I go full preventative and swap in the new one, given the mileage, or do I wait until 'something happens'? (I'll keep the old one as an emergency spare if I do this, but by this logic could leave it there with a brand new shiny one as my emergency spare...)
    What would you do and why?
    Thanks!
    Nov 2015
    Black Rock
    I'd change it over. I'm at 130,000km (December 2013 build) and already thinking about a new one, perhaps sometime around 170,000km or if I ever need to do any major work on the engine (inlet manifolds, turbos etc).
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Sep 2014
    Baldivis WA
    Replaced mine at 160k km preventatively, i was getting some transient errors. Pulley bearing was also getting noisy.
    Alternator is at bottom right of engine (when viewed from drivers side) so not related to manifolds or top of engine access. relatively easy changeover, a few extension pieces. Hardest part is the cable at the rear,for some reason JLR decided to make this cable ridiculously short, so you're fitting the locknut and washer on blind.
    Feb 2022
    QLD
    Thanks guys - I think it makes sense to bite the bullet. Yup, I've seen some comments around that cable - I have large hands, so it'll be a bit of a curse-fest, but its only time, and overall the job doesn't look too challenging...
    josh.huber Guest
    Quote Originally Posted by Jpdv View Post
    You'll be right, I did one in 2hrs once so I could make it to pick my daughter up from school.. Had to come home and recheck everything. But if you allowed 3 you should be fine. I'd keep the old one as the spare.
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    Quote Originally Posted by Eric SDV6SE View Post
    Ain't that the truth. Denso unit which was new in 05/16, 105K km.
    Being replaced on Thursday this coming week as we are off on a 2 week jolly three days later.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Oct 2016
    Perth, AU
    Replace I reckon. They die, and when they do, they can take out a battery, potentially catching fire.
    I’m on my third at 215k…
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Jul 2013
    Never replaced mine and as far as Im aware its the original, at 408k
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    Feb 2022
    QLD
    Damn you Shane! Now I'm tempted to wait and see! It'll go on me somewhere horrible if I do, of course...
    So another question - do they tend to fail gracefully/slowly, or is it a sudden terminal grinding to a halt in the middle of nowhere? That would influence the chain of logic, I guess...
    Mar 2016
    Just. Change. It.
    2007 Audi RS4 (B7)
