Did you find any corrosion on the TCCM contacts? If so then the connector pins will have to be cleaned too, best done by removing them from the shells. Sometimes the TCCM pcb is irreparably damaged by corrosion.
However a canbus fault at the TCCM will cause every downstream module to post faults so unlikely a fault with the TCCM.
The suspension module may be faulty if the fault can't be triggered by wriggling the wires at the rear harness connector at the suspension ecu.
