Results 1 to 10 of 15
Thread: Winch to ARB winch bar.
    May 2009
    Tatura, Vic
    Who has an ARB winch bar with a winch fitted with synthetic rope?
    I have the bar and I am looking at getting a winch with synthetic rope.
    I have been told that I will need a spacer kit for the hawse fairlead. Looking at the bar this makes sense.
    However looking at ARB fitting instructions, it looks like I need to also fit some spacers between the winch and the bull bar.
    https://www.offroad24.eu/resource/pd...s2-3500620.pdf
    Rather than the ARB spacer kit, for not much more coin I could fit a Factor 55 thick hawse. I love Factor 55 stuff.
    Factor 55 Fairlead 1.5" Thick
    Would this work instead of ARB kit?
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Jan 2017
    Geraldton WA
    I had an ARB winch bar fitted to my D2a.
    No need for spacers But an offset fairlead is needed
    4.6m Quintrex boat
    May 2009
    Tatura, Vic
    Can you explain what you mean by offset fairlead?
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    May 2009
    Tatura, Vic
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Jan 2017
    Geraldton WA
    Quote Originally Posted by d2dave View Post
    Thats the one
    The standard fairlead doesnt fit correctly (Not central on the opening) on the ARB bar as it allows the rope to chafe on the bar itself, The offset fairlead sorts this out
    4.6m Quintrex boat
    May 2009
    Tatura, Vic
    So the winch will bolt directly to the bull bar and all I need extra is the offset fairlead, yes?
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Jan 2017
    Geraldton WA
    I had a dominator 12000lb fitted to mine , Same bolt patern as a Warn.
    4.6m Quintrex boat
    May 2009
    Tatura, Vic
    Quote Originally Posted by trout1105 View Post
    Was your bar an ARB?
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Apr 2012
    Whyalla, SA
    Yes. Arb bar and a std footprint winch will bolt straight up with the offset hawse.
    The bar is only rated for 9,500lb so no need to go higher.
    Jan 2017
    Geraldton WA
    Yes
    4.6m Quintrex boat
