Thread: D4 rotary knob gearbox selector not functioning
    john m Guest
    My 300k km d4 rotary knob gearbox selector does not rise when the ignition starts my car. I don't get any warning/alarm lights come on while the engine idles away nicely though the neutral light continues to flash for a minute or so.
    Has anyone experienced this problem before? I'd be grateful for any thoughts on this matter.
    Brisbane,some of the time.
    Do a search on here,quite a few posts on the issue,its not uncommon.
    john m Guest
    Thanks Scary, in my case when nrma had a look they gave the rotary knob a good thump which then released it. It appears to be a common callout for them, their reasoning being the susceptibility to ingress of debris particles or spilt liquids around the gear selector knob causing it to stick a bit, probably increasing current draw to the servo(?) motor and subsequently bringing on a fault on the up/down circuit.
    Thanks again.
    Mar 2012
    melbourne
    Quote Originally Posted by john m View Post
    Thanks again.
    When I spoke to my mechanic about this issue and whether any preventative maintenance should be done he said no, just keep doing what you do.
    What I do I asked, yes he said , keep it clean and don't spill coffee or soft drink on it.
    The only ones he has seen that fail are in cars that are filthy....
    Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
    Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
    Oct 2012
    That knob design has got knobs on it!
