We've had our 2014 Puma Deefer for nearing two years with 170k km's.
It seems like everything has failed at some point and has us wondering if it's just the build quality slipping, or have we just been unlucky.
It's been towed to the mechanics a total of
8 times so far.
- Kill switch/immobiliser failed and needed bypassing
- Remote central locking doesn't.
- Intercooler split
- Fuel pump failed
- Sump pan rusted through
- 2x turbo's. (was actuator on both)
- New engine wiring harness.
- New rear axles
- New ECU
- New Oil crankshaft cover
- New hoses
- New timing sensors
Now the HD Clutch needs replacing & check the transfer.
The previous owners had some parts replaced or changed under warranty, including beefing up the clutch.
The also replaced the entire roof under warranty.
