Results 1 to 10 of 26
Thread: Problem starting 2016 D4 3.0
    Jan 2010
    victoria
    Hi Guys,
    Have a problem starting Disco.
    So my son left the glove box open all night and next morning would not start I assumed battery flat.
    Gave it another go in the afternoon it started, so assumed again battery arvo was not 2 like Melb morning. So enough charge as warmer.
    Went for a 45 min drive.. Came home and tried again an hour later and again did not start again
    Called out the RACV and they said battery was fine must be starter
    Called a few places of course 6-12 weeks wait time
    So mate ex mechanic helped pull out starter was a crap job to get too. He said worst in 35 years fixing cars
    Took it to local auto elec who put a load on it and all good.
    Put it all back together still the same.
    Rolled car out so can get his Pathfinder next to the Disco to try jumping no good.
    Same just get a click and nothing else then prob 10 seconds later you hear some more clicks not sure from what? Suspension?
    Honestly I thought it be battery or starter.
    Battery replaced 5 weeks ago holds charge trickled it to be sure.
    Any ideas.. Going to ring around Monday and see if anyone can get us in or have us on a wait.
    Even the local auto elec guys said maybe 2 weeks and they do not do Discos normally.
    Even though everything points back to the battery.. We just had the throttle body replace about 5 weeks back
    Dealer had the car that time almost a month as could not look.
    NSW SW Slopes
    Have the battery connections been checked including the earth connection to the body and the starter fuse attached to the battery terminal?
    josh.huber Guest
    When you say, won't start, is it cranking at all, out just nothing
    Mar 2016
    Firstly you can’t flatten the battery on the glovebox as the car will turn off all the electronics after a few minutes.
    The clicking will be the self testing of the EGR valves as they cycle back and forward.
    As Josh asked, I assume you’re suggesting nothing happens when you press the starter? You are pushing the brake pedal hard enough yeah? No one has been in the car and sucked all the vacuum from the pedal? You wouldn’t be the first after the kids have played in the car.
    2007 Audi RS4 (B7)
    NSW SW Slopes
    A faulty brake light switch can prevent starting but there wouldn't be any clicking.
    Jan 2010
    victoria
    thanks get a click click sound only on start then nothing
    Afterwards you hear a few more click noises not sure suspension or as you said EGR
    lower glove box light stays on it seems no idea why it does not time out like the dash and other lights.
    Not sure that is a problem with my Disco or all are like it.. Just left it again for nearly 10 mins still on.
    Was left for 12+ hours open to start with.
    So could just be a coincidence
    Brake pedal yes seen a few youtubes on that I pushed it in as much as I can.
    Wonder if a fuse/relay could of gone? Really felt like the starter to me.
    We tried to start a few times now.. So wonder if that causes other issues
    RACV not really any help.
    NSW SW Slopes
    The MY11 starter relay is mini relay 18 in the engine fuse panel so probably the same. Maybe swap it with another to see if there's any improvement.
    May 2014
    Point Cook, VIC
    The Battery Saver on the glove box lamp (and interior lamps if left switched on) should kick in after 15mins and only re-energise if the car is unlocked, or a door or the tailgate is opened, or the interior lamp switch is activated, or ignition switched to accessory.
    If it is staying on for more than 15mins you may have another electrical gremlin. It is actually designed to prevent the exact scenario you described if working correctly so also worthwhile investigating further (even if unrelated to your starting issue).
    Jan 2010
    victoria
    Quote Originally Posted by DiscoDB View Post
    The Battery Saver on the glove box lamp should kick in after 15mins and only re-energise if the car is unlocked, or a door is open, or the interior lamp switch is activated, or ignition switched to accessory.
    ok I leave it open more then 15 mins and see
    Kept on after the other lights went off which I thought was weird.
    I think left it 10 mins to check last time or around that and was on..
    Set stop watch and going now
    if not the battery that did it then wonder what. Did not start next morning after he left glove box open all night.
    Yes thought they should go off.
    Almost 97k on it now throttle body went a few months back they had the car for a month. Was serviced then as well.
    I think 3 weeks on and now this
    Our old D3 started spending much more time at the mechanics around 100k as well
    Jan 2010
    victoria
    13 mins goes off.. So was not the battery which I thought it was. Great
    So now any clues? RACV guy though starter.. We took it off and got tested by local auto elec said was fine.
