Results 1 to 9 of 9
Thread: Loud clicking from engine on idle
    Dec 2021
    Wa
    My Disco 4 (3litre) has a loud rythmic clicking coming from the engine on idle. It happens every week or so and disappears after a few minutes. On idle it sounds like a bit of the fan belt flapping around but doesn't correspond to engine speed when I hit the accelerator pedal. I'd say it's on a 1 second cycle. Any ideas what it could be?
    Mar 2016
    Quote Originally Posted by Chris D View Post
    It’s the viscous fan and it’s not considered a problem.
    2007 Audi RS4 (B7)
    Dec 2021
    Wa
    Thanks YM, that makes sense. I'll remove the shroud next time and check the noise against the rotational speed.
    josh.huber Guest
    Mine did it once, the belt tensioner had failed, near snapped in half
    Mar 2016
    Quote Originally Posted by josh.huber View Post
    Mine clicks all the time and has done it for all my ownership (6 years). Does it at start up. It’s different than your issue.
    2007 Audi RS4 (B7)
    NSW SW Slopes
    Watch the belt tensioner while the engine is idling to see if the tensioner jumps in time with the clicking.
    dazray Guest
    On mine I unplugged the fan and noise went away. Plugged it back in and noise came back.
    josh.huber Guest
    Quote Originally Posted by DiscoJeffster View Post
    Yeah it was your advice that made me ignore it till it got real bad hahahaha.
    Mar 2016
    A guess all clicks are not made equal Loud clicking from engine on idle
    2007 Audi RS4 (B7)
