Front lower control arms.
 ChatterBox
						Subscriber
						ChatterBox
						SubscriberSome of the laneways around our house are cobbled - there seems to be a rattle coming from the front right wheel area that's only audible on the cobbles: might it be a loose shock absorber? I can't see anything obvious and there's nothing noticeable at other times.
Arapiles
2014 D4 HSE
 ChatterBox
						Subscriber
						ChatterBox
						SubscriberThanks guys. OEM or non-OEM replacement?
Arapiles
2014 D4 HSE
Get the RRS Meyle arms from Advanced Factors in the UK. Meyle arms (bushes) are better than OEM and RRS arms are more "heavy duty" than Disco arms.
KIT683HD Meyle HD Front Lower Arms & OEM Bolt Kit R Rover Sport 4 Year Warranty LR029304 LR029306
If its only the rear bush that is worn, you can just replace those or both lower - don't even need to remove the arm.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
To leave the arm on the car you need a press tool. Two options available from memory. One hydraulic and kinda pricey the other mechanical.
If you pull the arm off the car, changing the bushes is easy with a press and associated gear. The argument is usually around price of arm and labour to change, plus you get a free ball joint. I've only changed arms once, was a waste of time. New bushes didn't last as long. I'm still on original arms at roughly 300,000ks and I've put quite a few bushes in, the ball joint is still fine.
You can do at home easy with the special press tool. Or a bit longer with a normal H frame press.
