Results 1 to 10 of 11
Thread: HD flange cap won’t screw off
    Jul 2018
    Essendon
    Anyone aware if there is any trick to removing the cap on the end of hd flange?
    After a recent 4wd trip backlash and ‘clunk’ had increased. Decided to check out condition of the rear flanges, in particular rear passenger where the clunk is believed to originate. Long story short even with usual persuasion (heat, violence, lube, leverage) does not want to budge. Is there a way to remove the circlip from within the cap? Drivers side is equally solid. PO installed the flanges so I believe they are screw off (is there other types?)
    May 2006
    Woolgoolga
    Screw off, rattle gun. Someone may have loctited them on
    350RRC's Avatar
    350RRC is offline ForumSage Silver Subscriber
    Quote Originally Posted by Vern View Post
    The ones engraved with 'MD' must have better thread quality.
    DL
    350RRC's Avatar
    Quote Originally Posted by Patrick110td5 View Post
    Very cosmopolitan set of wheel nuts you have there.
    DL
    Garfield, Victoria
    I had exactly the same problem with mine when I wanted to replace the brake discs. VERY tight!!!
    I used a Milwaukee 1/2" drive impact rattle gun with a 52mm impact socket. Came off easily.
    Would not budge with a breaker bar.
    BTW, the Milwaukee is the single most useful tool I have ever purchased!!
    Lionel
    Jul 2018
    Essendon
    Sounds like it’s time to buy an impact, cheers
    Mar 2010
    victoria
    Quote Originally Posted by 350RRC View Post
    DL
    Maxi Drive can sometimes be just as difficult to remove.
    Sep 2010
    Moe, Victoria
    I have also experienced very tight HTE caps ... I used a 52mm socket, 3/4" breaker bar - lengthened with about 1.2m of pipe, and an overweight middle aged man hanging off the end.
    Quote Originally Posted by towe0609 View Post
    And they aren’t easy to find these days!
    Oct 2006
    The Vines WA
    Worth having the right socket and means of taking the cap off (breaker bar or rattle gun), I believe greasing the splines is a routine maintenance item.
