Results 1 to 6 of 6
Thread: 265/50R20 all terrain tyres for 2008 RRS TDV8
    Jul 2010
    Lambs Valley - Hunter Valley, NSW
    Have been Googling everywhere to try and work out what to replace my tyres with; focus was to remain legal for insurance purposes; try and get a little more sidewall that was also a bit tougher than my current tyres (as I had damaged both front tyre sidewalls); not to have to modify anything and have a ride that was both more comfortable and preferably a bit quieter than my current Nitto Terra Grappler 275/45R20 tyres that were 6 years old with only about 3mm on the back and 5 mm on the fronts remaining.
    Legally in NSW I was restricted to a maximum of 31 inch diameter and I believe a load rating of 106 and a speed rating of H. I was also looking for a tyre that the manufacturer approved for 9.5 inch wide rims. I did consider going to 19 inch diameter rims but the choice of tyre was very limited.
    I ended up with a set of Falken Wildpeak AT3W in 265/50R20 in 111H; the diameter of these is 30.4 inches and approved rim width is 7.5 to 9.5 inches, so ticked all of the boxes from an insurance perspective.
    Limiting factor with my vehicle was the diameter, as on full right lock in the front left wheel arch I now only have about 8mm clearance at the front on the left shoulder of the tyre, seems fine on compression and also access mode.
    They are definitely quieter and it has removed most of the low speed jarring that I was having previously, ride quality was never an issue above 80 kph.
    Handling seems great although have not tried an emergency brake stop.
    Even though 10mm narrower than the previous tyre, they actually appear wider and look to bag out a bit better, I think they fill the wheel arches a bit better also. I have attached a few images including one of the vehicle at normal suspension height.
    Tyres cost me $290 each, fitted, balanced and the old tyres disposed of. Tyres were not old stock from overseas as retailer confirmed they were purchased from Falken Australia and also supplied me with the production date prior to ordering, being the 47th week of 2021.
    Hope this helps another member on their quest.
    Lee
    Jul 2019
    South Australia
    Looks good!
    Fairly chunky tread pattern as well.
    Do you have a IIDTool? there is an option in the tool to force the air suspension down to the bump stops. You could then recheck the tyre clearances at that height to be completely sure everything is good.
    I suspect other diagnostic tools would have a similar function.
    NSW SW Slopes
    My brother has been running the same size on his 2008 RRS and is in need of replacements. He's been looking for a better off-road tyre so I suggested these tyres.
    Jul 2009
    Mid North Coast, NSW
    51.4 KB
    Im confused, as i thought legally you couldnt change the external circumference of your wheel, so if you wanted large wall you needed smaller rim ...
    our factory tyre is 275/50/20 which is 28.7"
    NSW SW Slopes
    Factory is nominal 29", varying slightly depending on the particular rim and tyre size fitted. 1" oversize is allowable making nominal 30" legal and 30.4" isn't far from a nominal 30".
    Your size should be 275/40R20 or 255/50R19, noting that many owners fitted the D3/D4/L322 30" size of 255/55R19 or 255/50R20.
    Jul 2009
    51.4 KB
    Thats good to know, when i google now im getting results saying 50mm greater on 4x4 so 2" ?? bonus ?
