Thread: Introduction & Windsor Caravan Question
    PatrickC Guest
    Hi I’m new here & am new to caravanning. I have a question which I hope people can help with?
    We’ve a 2nd hand Windsor Genesis 2006 model with 2 water tanks & 1 grey water tank. There is one filler point that, I believe, supplies both tanks & 2 breathing holes that I take the caps off when filling. We’ve a water level indicator that shows each freshwater tanks’s level. At the moment 1 tank has just run dry & the other appears full. However much as the pump is trying to pump it is spluttering & only delivering a drop of water. QUESTION. is there a switch/valve somewhere we need to switch over to access the 2nd tank???? I can see 2 pipes coming up from below as if there are 2 separate feeds to the pump but of course it’s hard to tell. The in line tap is open for both pipes.
    Any ideas welcomed.
    Jan 2017
    Geraldton WA
    I had a simmilar problem with my Jayco 20' expander.
    It turned out to be a kink in the outlet/supply hose from the rear tank which I sorted by putting an elbow joint wher the kink was, Check to see if you have the same problem
    4.6m Quintrex boat
    PatrickC Guest
    Thanks - I MAY have solved it. If I turn off the feed from
    one tank the other seems to work. Maybe it was sucking air from the empty tank?
    May 2003
    On The Road
    With any twin tanks you need to physically open and close water line taps usually under the sink or close to the pump.
    PatrickC Guest
    thanks Pedro - I think that’s working for me 👍🏻 … so basically leave the line open on the tank you’re using?
    NSW SW Slopes
    Its easier for a pump to suck air than water.
    May 2003
    On The Road
    Quote Originally Posted by PatrickC View Post
    yep,, you'll hear it when its empty......
