Results 1 to 8 of 8
Thread: 2010 centre console removal
    May 2019
    I am fitting a reverse camera to my Disco 4 and need to access the Fakra plug that is located under the centre console. I can remove the upper part that has the gear change gate and 4wd controls but need to remove the lower part and have no idea how it is attached to the floor.
    Can anyone advise me ?
    Mar 2007
    Kalgoorlie WA
    Pretty easy when you see someone else do it. I have had mine out a couple of times now (MY2011) and it is easier the second time.
    See video below from PowerfulUK.
    How to remove lower center console gear change on Land Rover Discovery 4 - YouTube
    Cheers .........
    BMKAL
    May 2019
    Thanks, looks like I will have to dismantle a bit more to get to the reverse camera feed
    Mar 2016
    Adelaide
    In the 2013 there’s a reversing camera fakra plug under the upper rear trim (under the upper brake light) if that’s any help to you.
    "Land Rover - making mechanics out of everyday motorists for nearly 70 years"
    Jan 2015
    I did this in my MY14 so I know it is a little different to yours but are you sure you need to remove the lower part of the console ?
    Once the top section is off you should be able to access the plug under the matting as per pic below...
    Is the cable with the Fakra plug there in a 2010 model ? I could be wrong but was under the impression that this may have come in later models ? Have you located the other end of it in the tailgate ?
    David
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
    May 2019
    Thanks everyone. I had to take out the whole console because the fakra was tucked well under the carpet. There are two security bolts at the rear adjacent to the seats. They are covered by a mini air vent things. Plugged other end of cable into head unit. Located other end fakra above rear door opening and am just waiting on an rca to fakra cable to plug in to the aftermarket camera. This kit came with the car when I bought it and was supplied by Old Jaguar
    LRD414's Avatar
    Oct 2014
    Quote Originally Posted by ramrod View Post
    Bit late now but a Fakra connector is available with very easy access in the rear. Details in this thread:
    Switching another camera on to the D4 screen
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    May 2019
    Thanks Scott. I found the rear fakra which will be connected to my camera. That cable runs through the car and terminates with another fakra under the console. I have connected the front fakra by cable to the head unit. It just saves running another cable from front to back when there is one already there for that purpose.
    I am glad you posted that link as it shows how to do another project I was thinking about - fitting a rear camera to the caravan. Cheers
