Thread: Discovery 4 SDV6 hard starting
    Jan 2010
    Lyndoch Brossa Valley
    Engine turns over ok but does not fire. After waiting some 2-3 mins with ignition on starts ok. Is this sign of fuel tank pump on way out?
    NSW SW Slopes
    Have the crankshaft position sensor checked by graphing the RPM using a diagnostic tool during start-up.
    Mar 2016
    Having had this exact issue, I concur with Graeme. A new Crankshaft Position Sensor sorted it. It’ll do this weird no start for some time and then it’ll fail on you whilst driving. It’s about then you’ll finally get a code that says what it is. As Graeme said, get a code reading tool capable of showing RPM and watch to see if the RPM signal stays solid. RPM comes from the CPS.
    2007 Audi RS4 (B7)
    Jan 2010
    Thanks Graeme and Disco Jeffster
    Quote Originally Posted by DiscoJeffster View Post
    If they had a CPS at each end of the crank they could throw a specific fault code for 'that' really serious issue.
    DL
