Originally Posted by
BradC
Whilst seemingly accurate, to try and elaborate a bit : LED's are a "high resistance" compared to a bulb. The cars are designed to detect a trailer by the current consumption of the indicators.
On the D3 it tests frequently (many times per second). On the D4 it tests when the drivers door is opened and closed. Compared to a 21W indicator bulb, a LED draws bugger all current, so an additional load resistor is required to make the car detect a trailer. On the D4 I believe it's only required on one Indicator. On the D3 it's a bit more complex.
Some people install the load resistor in the car and connect it to a switch that they turn on when they have a LED trailer attached. If the trailer isn't attached and the switch is turned on, the car still thinks there is one present, causing your issue.
Your D2 detects the trailer in a similar but more agricultural manner. Put a LED only trailer on and it won't know unless you have the same load resistors. On the D3/D4 it also disables the rear park sensors and changes the shift points (if you have a slushbox). I can't comment on the smarts the D2 may or may not contain because we've only owned a D1 and D3 and both had/have 3 pedals.
I think you'll find that LED's are very low resistance, not high. This is why you may need to add a load resister in the circuit to enable the trailer detect feature. With a D4, the "detection" signal is sent down the indicator circuit at door opening and also when either indicator is used, (as I'm led to believe). For my van, which uses a 12 pin flat plug, I made up a small "dongle" that plugs into the unused 12N round socket. It's a 12N plug, a bit of polypipe and 2 load resisters wired up to the 2 indicator circuits. Just plug itin when towing van. Works a treat.
2014 SDV6 SE, Fuji White, ARB bar, Fyrlyt 5000, Pioneer Platform, Traxide D4-5S, Maxxis 980 Bravo, GOE Compressor Plate, ICom-450 UHF, Red Arc Tow Pro.
Elite Murray 2 Caravan 24'4" Tare-2917kg, ATM-3500kg
