Results 1 to 10 of 14
Thread: L320 TDV8 body removal instructions
    NSW SW Slopes
    On behalf of my brother, can anyone assist with body removal instructions for a MY08 RRS with the 3.6 TDV8 engine? Even instructions for a 2.7 TDV6 would be very helpful.
    The RH exhaust manifold gasket is leaking significantly and it appears impossible to repair without removing the body.
    Thanks.
    I helped KLR do it quite some years ago but I didn’t see any instructions.
    The front and rear bumpers were taken off, a lot of the electrics were on multi-pin plugs designed for this eventuality. Brake lines had to be disconnected.
    It was a surprisingly quick job. I returned the following day to help put it back on but it was too late, the body was on.
    I posted some pix on AULRO.
    NSW SW Slopes
    Thanks Ron. I suspect that it will be a slow job feeling his way although hopefully because the vehicles are designed to be split in this manner, there won't be too many nasties. My D4 was separated early in its life by the dealer and the only adverse affect was a loose steering column joint.
    Mar 2018
    Perth (near Malaga)
    This is for the D3, but it should give you a general idea.
    Body - TDV6 2.7L Diesel.pdf
    NSW SW Slopes
    Thanks Brad. That should suffice, making him much more comfortable that something hasn't been missed.
    The body removal section is missing from the copy of the WSM that I provided some time ago.
    I've just realised that I didn't see if I could still get onto Topix to retrieve it.
    Jul 2020
    Urila
    The workshop manual available for download via AULRO somewhere is missing section 5 - Body and Paint.
    Body removal is section 502.
    I have a version that includes that section, though it says for the TDV6 I used it recently on my RRS TDV8.
    The PDF is about 220MB if someone lets me know how to get it to you
    May 2010
    Mindarie, Western Australia
    Peter
    Have you tried compressing the file to see how big it becomes. Assuming a PC....Right click on the file, "send to" Compressed (zipped) folder
    Gary
    2007 Range Rover Sport TDV8
    Modified 1996 p38a HSE sold
    Jul 2020
    Urila
    Quote Originally Posted by mtb_gary View Post
    Peter
    thanx for suggestion however PDFs are pretty compressed already. Just in case I tried and it went all the way to 221MB. The AULRO file upload manager has a limit of about 9.5MB on PDFs
    Jul 2020
    Urila
    Just section 502 - Body Removal attached: RRS_workshop_manual 2007 2008 2009 - 502BodyRemoval.pdf
    All section 5 is 32MB, I don't know how to attach that.
    Oct 2012
    Thanks.
    Plenty of YouTube videos including Dazza Aztec has a very good ones
    LAND ROVER DISCOVERY 3, DISCOVERY 4, RRS BODY REMOVAL - YouTube
    LAND ROVER DISCOVERY 3, DISCOVERY 4, RRS BODY REFIT - YouTube
