Results 1 to 8 of 8
Thread: Battery Size In A Jump Starter Pack
    May 2009
    Tatura, Vic
    Can any one tell me if there is a way to know how many true amp hours are in a portable jump starter.
    I know this will vary depending on its size.
    I have a son coming back from USA and the unit that I want says 2000A peak 20000mAh
    Now to me this is gobberlygook. To travel with it on a plane a lithium battery has to be under 100 watt.
    How do I or airport authorities calculate this?
    This is the unit Robot or human?
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    May 2006
    Woolgoolga
    Quote Originally Posted by d2dave View Post
    20000ma = 20A
    20A x 12v = 240watts
    May 2009
    Tatura, Vic
    Quote Originally Posted by Vern View Post
    20000ma = 20A
    Thanks Vern. I understand ohms law. What I do have trouble with is that such a small device could have a 20 ah battery.
    This being the case I could run my 40 litre Engel for about 13 hours off this.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    BradC is offline Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    They don't. They have a total of 20AH @ a nominal 3.7V. That gets divided by 4 to get a nominal 14.8v (peak of 16.8 but it'll put a float on the car battery sharpish). So realistically 5AH, but then that's also Chinese Amp Hours, or 5AH PMPO.
    My power bank here is 26800mAH and the label says 99.16WH.
    Why import one when they are cheap as chips here - mine off ebay was a little less than $100.
    Supporter
    Mar 2018
    Perth (near Malaga)
    Right there on the specifications page: Capacity: 20000mAh (73.2Wh)
    So they've used a nominal voltage of 3.66V
    The way to know how many "true" amp hours are in the device is to do a couple of calculated discharge tests. I have a specific rig built to do that with a controllable load, a couple of GPIB volt meters and a calibrated shunt. But that's probably a bit more than you need.
    May 2009
    Tatura, Vic
    Quote Originally Posted by 101RRS View Post
    From my research it appears to be a really good brand and freight is free, so no much over a $100
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Apr 2019
    Make he doh me checks he can carry in checked in luggage Battery Size In A Jump Starter Pack
