Thread: Transfer box guide pins/dowel bolts
    Feb 2016
    New Zealand
    35.44 MB
    Hi,
    I'm about to pull out my transfer box on both discos and remember reading here about home made guide bolts. I've been searching to no avail, although I did read a bunch of interesting unrelated posts.
    Could somebody help out and tell me what length/thread bolts to get so I can make these.
    Thanks, James NZ
    '00 D2 V8 The orange off road truck. 2" lift, made my own rear bumper, still working on the front one
    '03 D2a TD5 The silver on road daily driver
    Nov 2017
    From memory they are M10 x 175 long. You need three bolts, preferably grade 12.9, and just cut the heads off then grind a small taper on the end. I will check mine tomorrow and confirm.
    Last edited by Max Headroom 2.3m; 28th August 2022 at 12:55 PM. Reason: Correct dimension - memory is rubbish
    Martin
    The secret to happiness is to truly want what you already have
    Oil leak?...Nah, sophisticated anti corrosion system!
    '04 D2a TD5 Manual "Snowy" - Daily
    '04 Def 90 TD5 "Hue" - New toy
    '03 Def 90 TD5 - Son's toy
    '16.5 D4 TDV6 - Gone
    Nov 2017
    Quote Originally Posted by James NZ View Post
    Hi,
    Thanks, James NZ
    Quote Originally Posted by Max Headroom 2.3m View Post
    I checked and they are 175mm long x M10 x 1.5mm pitch grade 12.9 and should be available from any decent fastener supplier. I also cut a slot in the end for easy removal. .
    These are the equivalent of special tool LRT-41-009 which is definitely for refitting LT230 to R380 gearbox. I would assume the same pins would be used for the LT230 to MT-82 gearbox but can't confirm. The protruding length of the studs has to to be the same or slightly longer than the gearbox output shaft but still leaving enough room behind the TC to get it up in place.
    Martin
    Mar 2020
    Higher grade bolts are probably a good idea, tho I think mine are just 8.8. I'd suggest getting a couple more bolts cos it's nice to be able to slide the T/C onto the guide bolts and then swap 2 out for bolts so there's less chance of dropping it on your face. Make sure you get the right length bolts and they're screwed in all the way because it's absolutely miserable for one to be too long. I ended up needing to screw one further in with a pair of vise grips.
    Nov 2017
    Quote Originally Posted by admiralranga View Post
    Higher grade bolts are probably a good idea, tho I think mine are just 8.8. I'd suggest getting a couple more bolts cos it's nice to be able to slide the T/C onto the guide bolts and then swap 2 out for bolts so there's less chance of dropping it on your face. Make sure you get the right length bolts and they're screwed in all the way because it's absolutely miserable for one to be too long...
    I seem to remember when the studs (cut off bolts) were screwed in all the way as per rave illustrated locations, they were just longer than the R380 output shaft. The LT230 lip seal is slightly recessed so by the time you get it on the studs the seal is safe. I only had the three studs as guides and supported the weight of the LT230 on a trolley jack. Extra studs wouldn't hurt. You are right in that you don't want the studs too long otherwise you may foul a rear cross member or support panel.
    ...I ended up needing to screw one further in with a pair of vise grips.
    Hence the slot cut in the end for a screw driver
    Last edited by Max Headroom 2.3m; 3rd September 2022 at 03:32 AM. Reason: Add photos
    Martin
