Results 1 to 10 of 18
Thread: my tyre pressure experiences
    Jan 2016
    Netherlands
    This last month I have had a nice vacation down to the mid south of france (auvergne) where I tackled some rough terrain and technical driving and I have been all the way up to the north of sweden mainly by avoiding bitumen.
    This gave me several sorts of terrain, short of dessert and extreme mud holes to try and test the car, tyres and driver mind you Since reducing tyre pressure is something relatively new to me I have been experimenting with it for quite a bit and I thought I just share my experiences with you lot, possibly hear back and learn some more.
    Firstly I had to figure out what my normal tyre pressures on bitumen should be. Since I changed the tyre size on my car from the standard 255/65R16 to 235/85R16 I was at a loss for quite some time as to how to get to the optimum tyre pressure. I did not just want to mimick the standard "40 psi" setting I see and hear a lot. Turns out, there is a way to calculate the optimum (minimum) tyre pressure which I used:
    • take the load rating of a tyre
    • take the maximum pressure of the tyre
    • take the weight of the car and preferably
      • take the weight per axle (since front and rear often are different)
    • divide that number by 2 (2 wheels per axle) if you know the weight per axle else divide by 4 if you only have vehicle weight
    • find the ratio between the max weight rating and the actual weight per tyre
    • apply that ratio to the max tyre pressure to find your tyre pressure.
    ie I have a tyre that can handle 1380kg per tyre at 5.5 bar or 80 psi. My front axle is rated at 1380 kg and my rear at 1820 for a total of 3.2 tonnes. (yes this would make me 400kg over GVM). I used these figures as an absolute max, knowing full well that I am probably right up to GVM.
    This would give me the following numbers:
    1360/2 = 680 | 100/1380*680 = 59% so 5.5 / 100 * 49 = 2,7 bar or 39 psi (well wouldn't you know! nearly 40 psi)
    1820/2 = 910 | 100/1380*910 = 66% so 5.5 / 100 * 66 = 3,6 bar or 43 psi (funny, that is really close to 40 but almost a full bar of difference... freedom units, they always catch me out!)
    Since I do not weigh THAT much I settled on 3.2 in the rear for my trip.
    End of the section that would possibly fit more in the technical section of this forum
    On to my actual experiences. I reduced my tyre pressures to 20 in the front and 25 in the rear for most of the work I did. I did not drive hot dusty sand or sloppy mud but mostly muddy ground with a firm base, rocky ground with a single spot of rock crawling and gravel/dirt roads where the gravel could best described as 5cm rocks.
    What I found is that on slow going, often even low range driving in the auvergne on all sorts of terrain these pressure performed well and I had no problems with the handling of the car when we had to do a very short stretch of bitumen between the offroad lanes (top speed 60kph for no more than a few minutes). What did seem to happen however is that due to the weaker side wall I had trouble with a particularly off camber rut that I wanted to straddle. The tyre wanted to form to the bank quite well and the increased footprint made for a lot of extra grip but due to the flex of the tyre, it was also pushed inwards eventually forcing the smooth sidewall (past the sidewall "biters") to end up on the dirt and I slid right in. It would seem a higher pressure would have worked better, contrary to popular believe.
    In regards to the gravel and dirt tracks I have found that 25 front and 30 rear reduced corrugations discomfort noticeably but going further down to 20 front and 25 rear I was able to find the sweet spot of minimal discomfort and reasonable speed (70kph) but it had the added effect of making the car a lot more prone to wandering from rut to rut. I also chalk this down to the tyres themselves. I used to run wrangler MTR kevlars in the same size and they behaved quite a bit more than my current falken MT's. I did not feel the need to go down even further as a test but I did go (or start rather) higher with 30 front and 35 rear which was hardly an improvement in anything.
    Thus far my limited experience with tyre pressures. It leaves me wondering if there is such a thing as the right tyre pressure
    What are your experiences? Did I miss anything?
    -P
    PS mods, There is some techincal stuff in here but I felt that this was a campfire yarn to be spun, feel free to move it though.
    DiscoMick Guest
    Interesting calculations.
    What vehicle?
    Our Defender on 235/85/16LT Hankook ATs runs 46 rear and 36 front on bitumen.
    I lower them by about 30% on easy off road, but go down to low 20s on sand.
    Strong sidewalls are important if pressures are being significantly lowered.
    Quote Originally Posted by DiscoMick View Post
    As is consideration for ambient temps speed and terrain.
    If you run them too low on corrugations on a hot......tulip killing.........40C+ day in Oz you'll run the risk of catastrophic sidewall failure methinks.
    DL
    Yass NSW
    Heat is the killer of sidewalls if you are running lower pressures at more than 70-80 KM/H then you need to consider speed. Mightn't be an issue if you are driving back to camp after a trip in Tassie but not so good if you decide that 100KM/H on the Oodnadatta track is appropriate when you have dropped your pressure to low 20s.
    On the 130 with 265/70/16 I generally drop to 24 front/26 rear on most off-road tracks and adjust from there if I need more traction. On the Disco 3 28psi was my go to pressure off-road running 265/60-18 tyres. It's pretty easy to check your sidewall temperature, if it's too hot to touch slow down or add more air.
    Regards,
    Tote
    Tyre pressure is always a compromise, between ride, rolling resistance, ground pressure, handling, and tyre life. So there is no ideal pressure.
    Of course, you could always go by the driver's manual. But even there, there are problems knowing what to do. I have in front of me, owner's manuals for Series 2a 1963 and 1970 and Series 3 1981. (these are essentially identical vehicles)
    Tyre pressures for the same radial tyre, same size for a 109. Pressures in psi, in the order 1963, 1970, 1981
    Front, normal use, load under 250kg - 20,25,25 Load over 250kg - 20, 25, 25 Emergency soft - 15, 15, 15
    Rear, normal use, load under 250kg - 20, 25,25 Load over 250kg - 35, 35, 42 Emergency soft - 26, 35, 35
    For my 1986 110, similar vehicle, same radial tyres, they have a more complicated schedule. (pressures psi front/rear)
    Load up to 500kg up to 105kph 35/35 Up to 120kph 45/45 Over 120kph 50/50
    Load 500-1000kg " 35/45 " 47/55 " 55/62
    Load over 1,000kg " 40/50 " 50/60 " 60/65
    And tyres may be reduced from these pressures for cross country operation by 15psi.
    So for the same tyres on similar vehicles we have a recommended pressure range from 15 - 65psi depending on load, speed, conditions - and when the recommendation was made!
    On my 2a, mostly used on unsealed road, but short on bitumen trips, I use 30/30psi or 30/40 loaded - but 35/35 for long highway trips, and as low as 12/12 when the paddock is very soft.
    On the 110, I routinely use 35/35 unloaded, but 35/45 when fully loaded, increasing to 40/55 on long trips with temperatures over 40. And I have used as low as 15/15 when the road is very bad, especially deep dry sand, although it also helps a lot on soft mud with no bottom.
    Low tyre pressures should be avoided where the ground is hard and there are sharp stones or sticks, to avoid sidewall damage, although low pressures do help adhesion on steep rocky surfaces.
    Jan 2016
    Netherlands
    What vehicle?
    It's a 1998 P38 range rover.
    I agree on sidewall strength but that also determines tyre pressure in a significant way since very stiff sidewalls tend to bulge less and to get the same footprint length you need to air down more. In reducing tyre pressure I tend to do two things: look at the sidewall bulge visually, I have a MT with sidewall biters that offer good protection but I never run them so soft that they already make significant contact with the surface when stationary. I also stop after driving a while and feel the tyre temperature by hand, both sidewall and tread. If I can't touch it properly, it's too damn hot (and thus soft).
    Regarding the different tyre pressures per year, that is an interesting little nugget I guess that is because tyres have evolved and thus the manual had to keep up? I have also noticed a trend like that with oil type and change interval on the rover V8 engine. That was more of an environmental and marketing though I guess since afaik there was never any change in the internal tolerances that it warranted thinner oil and a longer change interval.
    Anyway, I digress... All in all I found the experiment to be worth while since it gave me a bit of a basis to go on when I am on my trip. I guess I ended up a bit too soft in the end and I should run a tad more. With temps in northern sweden already down to freezing at night and around 8c during a sunny day, my tyres stayed very cool.
    Thanks for sharing!
    -P
    Jan 2010
    Quote Originally Posted by prelude View Post
    I agree on sidewall strength but that also determines tyre pressure in a significant way since very stiff sidewalls tend to bulge less and to get the same footprint length you need to air down more. In reducing tyre pressure I tend to do two things: look at the sidewall bulge visually, I have a MT with sidewall biters that offer good protection but I never run them so soft that they already make significant contact with the surface when stationary. I also stop after driving a while and feel the tyre temperature by hand, both sidewall and tread. If I can't touch it properly, it's too damn hot (and thus soft)................
    -P
    Have you considered fitting a TPMS Tyre Press. Monitoring System as they can show temperature as well? They do work as I was on a dirt road one hot day, nearly 40 degrees and was looking at a map deciding where to go next with the engine idling, and a breeze blowing in the direction of one of the rear tyres and the TPMS alarmed at the 50 degree setting.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    Jan 2016
    Netherlands
    It's on my todo list It is a bit of work to figure out what system to use. I think the type that sits on top of the valves is a bit of a risk but the same goes for the internal type, when changing tyres you could well have them damaged... I will have to look into this.
    -P
    Oct 2011
    Fremantle WA
    -P
    Like any number of others I have the external screw in type (Safety Dave version). Never had a problem towing or off road - but I do add a little piece of garden hose on each stem for added protection. Externals of course is easier to use if changing wheels.
    Quote Originally Posted by RANDLOVER View Post
    Didn't know they could do temp as well...........got a link?
    DL
