Results 1 to 10 of 16
Thread: 300tdi down on power
    Geelong, VIC
    Currently working through an issue with my 300tdi 130 being down on power.
    I did a 500km round trip yesterday with a trailer. Everything was normal on the way there - cruising at just over 100kmh in 5th.
    On the way home I could only manage 90k's on the flat - and that was in 4th as there was no way it would pull 5th gear.
    Empty trailer on the way there, and only a ride-on mower - about 300kg and a bit of wind drag - for the return trip.
    It feels like the engine just isn't coming onto boost. At 90k's in 4th there is throttle response to about half pedal - but pressing the pedal further after that makes no difference. If you put your foot to the floor you can lift up to about half travel before any reduction in power.
    It was an on-road trip, so no 4WD/mud/water etc involved. Same tank of fuel on the return trip.
    Engine is 100% standard with zero tweaks done to the fueling etc.
    Unfortunately no boost or EGT gauges fitted so no clues there.
    Investigating today from a low boost/fueling perspective - so far I've done the following with no improvement or obvious issues found:
    • Removed and cleaned the fuel sedimeter - only a small amount of crap
    • Changed the fuel filter
    • Removed the turbo inlet hose and checked the compressor - looks fine and is spinning with engine running
    • Removed the top intercooler hose and checked that the turbo is providing some boost when the engine is revved
    • Checked that the injector pump boost sense hose seems OK - blanked one end and blew into the other to check it was holding pressure (it was)
    • Removed the boost sense hose from the IP, fitted a bit of tube and blew in that to make sure the diaphragm isn't obviously leaking/split.
    • Driven it again today without the trailer after doing all the above - definitely down on power and only just makes 100k's on the flat.
    I think the next thing I'll do is hook up a boost gauge and see what its doing, but thought I'd post the issue here in case I'm missing something obvious.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Apr 2016
    I'd say worth checking .. the wastegate levers. Could be stuck(rusted up or something). could be sticking half open or something
    You don't need special tools or gauges, just swing the pivot with a spanner/shift spanner see how it feels. If a bit sticky then maybe spray it with some penetrating fluid or something.
    If you have a air compressor and a way to inject some air into the hose (and air blower nozzle) could be worth trying to inject some air in there to see how it operates.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Aug 2018
    Bendigo
    Check your lift pump too, I had one fail with similar results.
    Also check the boost hose especially the rubber connector at the turbo waste gate. If it is still the original, the rubber goes hard/perishes.
    Plus check the hose clamps on all the intercooler piping. Could be a crack in the intercooler as well.
    Andrew
    1998 Landrover Defender 300Tdi 130 HCPU Expedition
    1972 Peugeot 504 Sedan - Daily Driver
    Andrew
    Sep 2013
    Darwin
    12.74 MB
    As suggested by 86mud, check the (edit) boost line that runs from the injector pump, via the space between the back of the engine and firewall, to the turbo. The rubber attachment tube at the turbo deteriorates leaving the (edit) boost line hanging. In this condition the vehicle will get to speed at a snails pace.
    Geelong, VIC
    Thanks guys.
    I ran a separate line from the turbo to the IP sense port - no change.
    Added a pressure gauge to that line. Not showing any boost.
    If I remove the top intercooler hose and blank it off with my hand I get about 7psi on the gauge.
    Also blanked off the hose to the wastegate to test. Same deal - no boost on the gauge.
    I think it’s looking like a dead turbo.
    Any suggestions on quickest source for a replacement?
    I haven’t got time to be modifying it with different turbo etc - so just want a new CHRA to drop in.
    PS: Forgot to say I’d applied 10psi to the pump boost port while giving it a decent rev. Got a bit of smoke which isn’t there without pressure applied.
    That fits with lack of boost keeping the fueling down.
    Steve
    Apr 2016
    Quote Originally Posted by steveG View Post
    Thanks guys.
    How did you check for pressure?
    if on a drive through the gears .. OK.
    But ...
    If just revs whilst sitting still, it won't produce a lot of pressure just revving, it needs a load.
    Is hose for the gauge long enough to get into the cabin and take for a drive?
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Geelong, VIC
    Yes, I also road tested with the gauge in the cab.
    There’s a very slight positive pressure if you put your finger over the end of the hose, but not enough to get even a slight movement on a 40psi gauge.
    Steve
    NSW, Australia
    Hi Steve.
    I recently had my 300Tdi turbo (standard one) redone by MTQ Engine Systems at Wetherill Park in Sydney, who are a Garrett master distributor.
    It was only $682, which included media blasting the housing and installing a brand new genuine Garrett core. Pretty reasonable I thought, for what is essentially now a brand new turbo.
    MTQ appear to have a branch in Dandenong, and I'm sure they'd ship you a core if you wanted to DIY.
    Andrew.
    [B][I]Andrew[/I][/B]
    [COLOR="YellowGreen"][U]1958 Series II SWB - "Gus"[/U][/COLOR]
    [COLOR="DarkGreen"][U]1965 Series IIA Ambulance 113-896 - "Ambrose"[/U][/COLOR]
    [COLOR="#DAA520"][U]1981 Mercedes 300D[/U][/COLOR]
    [U]1995 Defender 110[/U]
    [SIGPIC][/SIGPIC]
