Results 1 to 8 of 8
Thread: what happens if you use too thin a head gasket?
    I spun a big end bearing the other week, and have rebuilt a 300Tdi engine with new STD crank and pistons. I had to use a couple of the old oil rings though after snapping them.
    There was piston protrusion on this engine, which there wasn't on my previous, but I didn't measure it properly. I went for a 3 hole gasket and now that it's assembled it has a harsh noise on acceleration (haven't driven it yet, just revving it in the driveway). I suspect I might have had to use a 0-hole gasket.
    Can someone confirm that this would be a symptom of using a thinner head gasket? Or should I look elsewhere?
    Thanks in advance, Michael
    Oct 2020
    Elizabeth North SA
    3.15 MB
    on my Td5 the 3 hole is the thicker gasket, so just a quick google and it seems tdi are the same.
    so 3 hole good choice with piston protrusion. with thinner gasket pistons may bump into head/valves so you don't want to go thinner unless you measured the piston protrusion and want every miniscule bit of compression gain.
    I don't know jack about tdi but is the crank, cam and fuel pump all 'timed' to how they should be? maybe fuel not injecting at right point or valve train not in sync with crank?
    double check the basics
    St Helena,Melbourne
    4.28 MB
    Pistons would come in contact with the valves, was it a new head or did you have yours skimmed ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Quote Originally Posted by johnp38 View Post
    0-hole is the thickest head gasket for a 300Tdi Suited to 0.81-0.9mm protrusion. I took the head off and it was 0.8 witha feeler gauge, so I went for the thicker gasket.
    The timing was done with the motor out of the car, so visualisation was good. I double checked the pin timing with a DTI and it was 1.55mm lift.
    The noise still seemed to be there, but did quieten once the car warmed. I wonder how much is my imagination.
    Turners head, 2 years old.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Michael2 View Post
    so not machined at all ? you'll need the thickest gasket then.
    1974 VW Kombi bus
    Or two thin ones?
    That'd be a legendary bodge.
    DL
    Brisbane,some of the time.
    Quote Originally Posted by 350RRC View Post
    Or two thin ones?
    DL
    Done that a few times on large open drive refrigeration compressors,no issues
