Results 1 to 10 of 35
Thread: Air suspension struts - how can they still be good after 250k?
    Sep 2019
    Noosa
    On a number of occasions i’ve seen people on the forum say that their air struts are still going strong after 200,250,300+ kilometers. But how can suspension be any good after that many k’s? Surely the strut part (which i assume handles small bump compliance) is shot around the same km’s any regular shock strut is shot - 80-120k or whatever. I’ve assumed that what’s happening is that the strut part is worn and performing poorly, but is masked by the air suspension. Or, is there something special about this suspension that allows it to perform well even with big kms on them?
    This fella cut one open.
    Why Do My Air Shocks Fail - What's Inside Air Shocks Cut Open - YouTube
    Oct 2012
    It’s a top priority when I save up but at 260k km on original 15 year old units no leaks and still drives well on all surfaces. I don’t know why either.
    NSW SW Slopes
    Air-springs don't have a length to which they try to return to so won't induce bouncing when shocks are worn-out. Hence unless worn shocks are tested with extra load or adverse road conditions they won't normally exhibit the severe characteristics that steel springs will induce. Due to the road conditions where I drive, my D4's shocks became rather useless by 80K kms but only after 40K for cheaper after-market shocks. I knew that the CVDs on my L322 at 100K kms weren't in great condition for normal unladen driving but on undulating surfaces with the van attached the shocks showed that they were indeed very worn-out, being incapable of preventing both front and rear bounce.
    Nov 2017
    West of Perth
    I've been having a similar conversation with my indy.
    Having just replaced the front pair (full set of struts - bags with shocks) due to a leak in one of them, I asked about the rear shocks in particular, because any other car I've had with this mileage - 160k - would be on its second set by now.
    He assured me that he rarely ever has to replace any, as they seem to go forever. Graeme's explanation goes some way to explaining why, thanks.
    I am not sure if I can tell if the rears are worn or not. I do long distances on rough roads with a loaded car only, and so far I can't pick it.
    This may well change when I whack a camper on the back in the next year or so, but for now I'm hanging onto my cash.
    If at first you don't succeed, that's one data point. - xkcd
    2011 Discovery 4 SDV6 HSE
    Sep 2014
    Baldivis WA
    120 to 160k kms seems normal for these. The airbag do hide or mask a lot of the wear in the shock themselves. Changed mine at around 200k, once out of the car and deflated, the old shocks were a good 50mm shorter than the new, no damping left in them at all.
    Bunbury, WA
    I did my struts at around 220,000km. I had noticed a subtle twitchiness when changing lanes, but no other major symptoms. The new ones ride like new again, not that the ride with the old struts was bad at all!
    Yes they seem to have an amazing life span.
    Oct 2012
    My only fear is the new BWI owned versions will not be as good.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by PerthDisco View Post
    AFAIK still made in the UK and are exactly the same as original so shouldn't be any difference.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jan 2020
    McGowanastan
    I replaced mine with BWI struts on all 4 corners and reckon after 20,000 k's the ride is worse than my original which done from memory 180k or close enough. I also replace all the arms at the same time so can't blame worn arms for my suspicions about the struts.
    I have a spare front and rear strut that a got from a forum member that were fitted with bilstein shocks and am looking at purchasing some new shocks and fitting to the BWI units .
    Cheers Bulletman
    Jan 2020
    McGowanastan
    When I asked AF im positive they told me they are made in China by Beijing west industries , but were made to the same standard as the Delphi struts.
    Cheers Bulletman
