Results 1 to 3 of 3
Thread: Air suspension fault after wheel bearing hub replacement
    Mservice Guest
    Hey guys ! New here … I have an LR4 2.7tdv6 2010… replaced the front right wheel bearing hub assembly, rotor and brake pads this past weekend … and after doing the front right (ie before conpleting the front left) … the vehicle has developed an intermittent fault…
    At first drive of the day - it yields multiple red air suspension faults and drops the car to the bump stops… on a drive into toowoomba it may do this 4 or 5 times.
    I made it to the shops - and then it miraculously fixes itself and has no issue raising and holding.
    Fixed the front left hub assembly etc and drive it again …. And same issue. Starts the day with multiple fault occurrences of failure to raise the vehicle.
    I noted on one of these fault occurrences that the front right wasn’t raising but the rest of the car was …
    Any ideas what sensor I could have buggered up when doing that work?
    josh.huber Guest
    The height sensor is in there. Connected to upper control arm. Make sure the orientation is right
    Jan 2012
    Welcome.
    Fault codes would help. You really need a code reader with these vehicles.
    As said above its most likely the height sensor & rod setup given the work you’ve performed, but could be something else and pure coincidence.
