Results 1 to 3 of 3
Thread: Cracked front diff housing??
    Geelong, VIC
    Anyone come across cracking in the horizontal weld on the long side of the front diff housing?
    I’m familiar with where they crack around the front cover weld, but haven’t struck this before.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    No, like you I am familiar with the cracking round the front cover. Both this, and what you are seeing, I suggest result from twisting of the housing caused by articulation (one side up, one down) with the bushes at the axle end of the radius arms being stiffer than designed. Probably exacerbated in the Isuzu by the heavier engine.
    Geelong, VIC
    That’s my view also.
    In this case the original cover was also cracked and had previously be welded multiple times.
    I’ve replaced the cover with an 8” pipe cap, but only noticed this crack while cleaning the rest up for painting.
    I’ve cleaned it up with solvent and then put some penetrant on the inside with the seam facing down.
    Will see if that makes its way to the outside overnight so I know if the crack is all the way through.
    Steve
