Results 1 to 3 of 3
Thread: Super extended mode
    Mar 2007
    Tarneit VIC
    Super extended mode
    Does Range Rover Sport pre 2012 have super extended mode like D3?
    Gus
    Oct 2012
    Super extended mode
    Yes, can, same car.
    Trick it by raising car then put a jack or block under chassis rail. Try to lower the car and when it senses this obstruction it will automatically go to Extended height. Then and only then you ask for Emergency height by holding brake pedal down for 5s while simultaneously selecting up.
    Emergency is about 70mm above Off-Road Height.
    You can stay in these monster truck modes up to 8kph.
    This and rock crawl will get you out of a bogged on sand scenario with minimal digging.
    Mar 2007
    Tarneit VIC
    Quote Originally Posted by PerthDisco View Post
    Yes, can, same car.
    Thanks Super extended mode
