Results 1 to 3 of 3
Thread: GAP ID Error list
    May 2003
    On The Road
    GAP ID Error list
    most of these will be "cascade" errors?
    anything stick out as weird?
    Model L494 - Range Rover Sport 2016
    Vehicle scanned on 6 Oct 2022 7:42:51 pm
    IIDControl 3.0.4 Build 90 Android - IIDTool BT V4.0 B2803
    ABS-Brake Module
    C0564-16 (28) ABS control module system - Voltage low - General electrical failure - circuit voltage below threshold
    ( on 30-07-2016 11:01:37 )
    BCM-Body Control
    B103D-49 (28) Right headlamp control - System internal failure - internal electronic failure
    ( on 05-10-2022 12:13:43 at 97844 km )
    B112C-87 (28) Interior motion sensor - Bus signal/message failure - missing a message
    ( on 05-10-2022 12:19:26 at 97844 km )
    B123B-86 (28) Front right turn signal - Bus signal/message failure - signal is invalid
    B13D4-86 (28) Right - Daytime running lamp and position lamp - Control - Bus signal/message failure - signal is invalid
    B146C-29 (28) Front right - Side marker lamp - General signal failure - signal is invalid
    B1C98-29 (28) Left corner lamp circuit - General signal failure - signal is invalid
    B1C99-29 (28) Right corner lamp circuit - General signal failure - signal is invalid
    B1D17-87 (28) Bus circuit - Bus signal/message failure - missing a message
    B1D17-96 (28) Bus circuit - Component failure - internal failure
    GSM-Gear Shift
    U0422-00 (28) Invalid data received from the body control module
    ( on 20-09-2022 08:03:36 at 97094 km )
    U3003-16 (28) Battery voltage - General electrical failure - circuit voltage below threshold
    GWM-Gateway module
    B1479-08 (A8) Dual battery junction box - General failure information - bus signal/message failure
    HVAC-Ventilation
    B1032-01 (28) Front right seat heater - General failure information - general electrical failure
    ( on 20-09-2022 18:53:14 at 97140 km )
    IPMA-Camera RVMirror
    U0002-82 (2F) High speed CAN communication bus performance - Bus signal/message failure - alive/sequence counter is incorrect/not updated
    ( on 05-10-2022 14:01:59 at 97844 km )
    IPMB-Camera
    B12BE-31 (28) Front left camera - Frequency modulation/pulse width modulation failure - no signal
    ( on 06-10-2022 13:24:21 at 97886 km )
    U0011-87 (28) Medium speed CAN communication bus performance - Bus signal/message failure - missing a message
    U2300-56 (28) Central configuration - System programming failure - Invalid / incompatible configuration
    ( on 30-09-2022 17:19:56 at 97509 km )
    U3006-16 (28) Control module input power A - General electrical failure - circuit voltage below threshold
    ( on 22-09-2022 18:51:43 at 97175 km )
    PCM-Engine TDV8
    P0658-00 (28) Actuator supply voltage A - circuit low
    Crikey! CAN Bus related?
    Jan 2014
    Perth Western Australia
    No, it all looks quite normal for a Land Rover
    Daz
