Before considering this you should know what you’re heading into. LR Time videos of their repair gives you a good start: Is this the end? Complete engine failure - Land Rover Discovery 3 / LR3 - Episode 1 - YouTube
 Fossicker
						Fossicker
						Hello everyone. In my Discovery 4 3.0 TDV6 it refused to obey and more precisely the crankshaft broke. I decided to fix it myself. I am addressing all those who have done it before, that is, what is also worth paying attention to / refreshing beyond the main fault so that the engine will be used as long as possible.
Can anyone recommend proven sources where it is best to buy engine parts? I will also be grateful if someone has a shop manual for the engine with technical data.
I tried to search this extensive forum but couldn't find the information I was looking for. If I missed something, I am sorry.
Fabian
Simon
2003 D2a TD5, ACE, SLS, Vienna Green.
The manual available on this website is really good mate, good luck with the build. Take heaps of photos and post them up. Plenty of people will be interested in your journey.
As for parts if I had to do it I would probably aim to buy genuine where possible. Depending on price
Good luck with the rebuild, way above my pay grade but am interested in photos as well. I believe my indie goes to BMI – Welcome to BMI's online store if that helps.
2011 SDV6 3.0L + Torus Kakadu, Winchbar, UHF, roof racks, 1 wife, 4 dogs, not enough fishing rods, and Wallabies supporter.
 TopicToaster
						Subscriber
						TopicToaster
						SubscriberThe manual doesn’t have bottom end info unfortunately (well mine doesn’t) but I did come across a Peugeot manual for the bottom end at one point which covers it off. I’ll see if I can find it and flick it through.
2007 Audi RS4 (B7)
If you become a patreon of LR Time you can access detailed data on the gear they used / built / bought and allows you to ask questions. He has the rebuild and parts books for everything. They did rebuild a 2.7 though although he does mention relevant component differences to the 3.0 quite a lot. The initial bearing set he bought was for a 3.0 not 2.7.
Unless there was valve damage the top ends last a long time although freshening up the lifters and chain gear is worthwhile.
 Fossicker
						Fossicker
						Thanks a lot to everyone for the answer. In general, I have already taken big steps and so far everything is going well.
simonmelb - I've seen their videos, they're very helpful. By the way, I saw a few other brave people who were my inspiration to take up this challenge.
josh.huber - already bought the manual from Dave and I'm starting to browse. I hope I will find all the necessary information when assembling the engine.
rambada - thank you for the information, I will have a look there without a doubt.
DiscoJeffster - This is not good news. I hope the manual I just bought will include this chapter. If by some miracle you found the manual you mentioned I would be very grateful.
PerthDisco - I have become a patreon already, thank you. LR Time is a real mine of knowledge.
Here is a link to video / time lapse from the progress of removing the engine from my Discovery 4 with body on.
Day 1
Day 2
Day 3
Hi Fabian,
Great work and great vids. Please keep posting as very keen to following your progress. Good luck.
BR David.
Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
Copying a few relevant and interesting short videos to this resource as a Plan B. Same process I think DiscoJeffster had done on his 3.0.
Land Rover Discovery 3 TDV6 Main bearings removal from under the Car. - YouTube
Land Rover Discovery 3 TDV6 Main bearing install - YouTube
tdv6 First Startup with New bearings - YouTube
Interesting pressure gauge he developed
Oil pressure Display/Gauge for Land Rover Discovery 3 tdv6 2.7 - YouTube
