Thread: Oil Vacuum pump
    Jun 2010
    Merrijig Vic.
    Oil Vacuum pump
    Time to change the oil in between scheduled service intervals.
    The easiest method seems to be sucking the oil out.
    Any recommend vacuum pumps, there seems to be a vast array out there.
    Tony
    My 20 TD 240 Defender
    Series 3 Ute
    Sep 2014
    Baldivis WA
    Quote Originally Posted by tonyci View Post
    Tony
    This is what I have, mine was AUD 20 when I bought it.
    9L Manual Waste Oil Fluid Extractor Pump Suction Vacuum Fuel Car Boat Transfer | eBay
    Mar 2007
    Talbingo - now Medowie
    Vacuum Pump
    Does it work on a D300?
    ok on the Disco made with the Pipe to use for the Vac Pump.
    Phil
    2022 D300 SE
    Sep 2014
    Baldivis WA
    Assuming the same or similar suction pipe dont see why it wouldn't.
    Mar 2016
    Quote Originally Posted by Eric SDV6SE View Post
    What do they say about assumptions????
    It doesn’t have one from my research.
    2007 Audi RS4 (B7)
    Apr 2015
    Hervey Bay
    I use them all the time and the best I've found is the OEM Tools brand. Good quality and suck really well. You also don't need to keep pumping with these, you just have to pump it up the once and it will keep sucking till it's full.
    I've used the cheap ones but they are too slow and loose their suck and I've had to keep pumping them every other minute or so.
    But if you only use it once every six months the cheaper ones will suffice.
    OEMTOOLS 24937 6.0 Liter Pneumatic/Manual Fluid Extractor 1.5 Gallon (6L) | Convenient Oil Change & Fluid Change Tool | Easy-to-Use Hand Pump and Vacuum Pump Functions | No Leaks, No Overfills : Amazon.com.au: Automotive
    04 L322 Vogue V8 - Work truck
    07 Freelander 2 TD4 SE - The wifes
    74 Leyland P76 Targa Florio - Aspen Green
    91 Kawasaki GPZ900R
    Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
    Jul 2003
    Mahn England
    Ex 300Tdi Disco:
