Thread: lpg filler position on a 110
    jasper110 Guest
    hi,
    i'm planning on relocating the lpg filler on my 110 from its current underneath the rear cross member position to recessed in the rear corner panel about 8" below the petrol filler.
    my question is, is this a suitable position for it and does the panel have enough strength to support the weight of the lpg nozzle when re-fuelling?
    many thanks.
    Mandurah. W.A.
    My county gas filler is in the fuel housing below the filler neck. Works fine!
    Maggsie
    jasper110 Guest
    thanks, how close is it to the petrol cap?
    May 2002
    Sydney, Australia
    Quote Originally Posted by maggsie
    Maggsie
    Any Pix? Looking for pointers when I install the Gas on my D100
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    On the SIII I fitted the recessed panel that goes on the body curve and mounts the fuel filler, then made a blanking plate out of some chequer plate alum. cut a holesaw hole in it and mounted the LPG filler. The whole set up was painted to match the body color and not only did it look good, but it meant I could refill without having to stoop down - very ergonomic.
    Maybe not for the 110 where you already have a recessed rear filler, but might be good for the 100".
    PM me if you want me to email a pic.
    St Helena,Melbourne
    4.28 MB
    I did the same with my rangie, removed the stock filler and rivetted a piece of steel sheet with the filler mounted in it.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    May 2002
    Sydney, Australia
    My D100 uses a a D110 2 door hardtop rear body - so have the same issue as the D110
    LRH
    Disco 4 SDV6 Auto
    RRC 300 TDI Auto
    Subaru GDA WRX
    Yamaha TTR250
