Results 1 to 10 of 20
Thread: Disappearing U-bolts
    May 2003
    On The Road
    I can sort of see one set of double nuts maybe vibrating loose, or nearly maybe one u-bolt snapping. But neither of these will make both u-bolts vanish...
    Is this normal for trailer axle u-bolts?
    Mar 2012
    Armstrong Creek, Qld
    Perhaps the composition of the u-bolts, i.e. country of manufacture, may come in to play here. Is this on the 'van, Pedro?
    'sit bonum tempora volvunt'
    Jan 2017
    Geraldton WA
    IF the U bolts have been over tightened it is common for them to fail, Loxens will stop them from vibrating loose and falling off as well.
    If one set has failed I personally would be replacing ALL of them with new ones
    4.6m Quintrex boat
    May 2003
    On The Road
    Yes, drivers side rear,,,,
    Yep, even Mrs Pedro is now concerned about the others,,,
    also that "-the wheels are held on by only 4 bolts???"
    Brisbane,some of the time.
    Nulock nuts will sort them,but they should be a one use item.
    Quote Originally Posted by trout1105 View Post
    Loxen? The drug for those of us with angina?
    Back down the hill.
    What is a Loxin?
    The Loxin is a shorter length thin wall internally threaded expansion anchor for weaker substrates such as brick, block and stone. For fixing to. Concrete, brickwork, blockwork. Features. Flush setting no protrusions when not in use.
    Did the original bolts have spring washers? If these get a little loose then the nut will work off. The u-bolt may stretch, resulting in the spring washer no longer holding the nut tight enough. Spring washers are prone to breaking. This results in failure of the locking mechanism. Use nyloc nuts. Even if the u-bolt stretches, nyloc nuts will not further undo.
    Aaron
    99.87 MB
    I hope she doesn't notice the hub is held on by only 1 bolt!
    Slunnie
    Jan 2017
    Geraldton WA
    I'm a bloke so I don't have one of them
    4.6m Quintrex boat
