Pretty much anything and Grays are unlikely to be any more forthcoming or to give you the opportunity to put a code reader on it. Could be a bargain (or spare parts)
Regards,
Tote
It says,
- Engine & Mechanical: Engine Light On
- What could it be?
- 2005 Land Rover Discovery SE SERIES 3 Automatic 7 Seats Wagon Auction (0001-20064224) | Grays Australia
Build date 11th Oct 2003
LROCV #1410
Regards,
Tote
I recall once I talked with an officer (via phone) in Grays' NSW office and he said all independent inspections are welcome including your own tools to plug in to READ the codes as long as you will NOT moving the car out of its current parking slot in their place, and also you will NOT trying to clear or remove the codes. You might verify this with VIC Grays' office and it might be Yes or No.
However, off topic a bit, I also had an (good) experience with Pickle Auction before and I know that we could do inspections with tools/code readers and with the similar conditions that NOT clearing the codes nor moving the cars. Anyway, we believe that Pickle has higher reputation of better car quality than many others because my friends did buy many cars from them without problems.
So you might give them a better negotiation for your own inspections.
Its a petrol V6 so as long as it runs there isnt much that goes wrong with these.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
Before: Ser 2a LWB, Ser 3 S/W, 1979 RR 2 door, 1981 LR Stage 1 V8 (new), 1985 LR 110 V8 County (new), 2009 RRS TDV8
Now: MY13 D4 TDV6. "E" rear diff. Cambo's magic Engine & Auto Tune. 1968 Austin 1800 Mk1 auto (my 5th)
