Results 1 to 6 of 6
Thread: Replacing suspension airbag
    Mar 2007
    Tarneit VIC
    Anyone can tell me how to disconnect the pipe from the airbag? Thanks
    Avoca Beach
    AFAIK you push in the black thing and it will be able to be pulled apart.
    Regards PhilipA
    Sep 2018
    Travancore
    You might find it easier to do with a small spanner (the tube itself is only 4mm) and pull the tubing where it goes back under the chassis rail once you have pressed the ring
    2004 Discovery 2a TD5 Auto Aspen Green AKA Robin
    2000 Discovery 2 TD5 Auto Alverston Red AKA Edward
    1997 Discovery 1 TDi Manual White - Gone but not forgotten
    1994 Discovery 1 V8 Auto - Gone once it consumed half the worlds resource of oil
    Mar 2020
    Adelaide Hills
    Push the silver metal ring inwards towards the air bag using a long nose pliers and you will feel the metal ring suddenly move inwards a couple of millimetres. then, while holding the metal ring at that position, pull on the plastic pipe and it should easily pull out of the little metal ring holder.
    Back down the hill.
    It's easier to remove the airline with the airbag in situ.
    Mar 2007
    Tarneit VIC
    Thanks everyone
