Results 1 to 4 of 4
Thread: Need help installing air horn
    Oct 2022
    Victoria, Australia
    Bought a cheap air horn from super cheap for my 01 disco 2 as the current horn is a bit pathetic.
    Just want some advice on how I should wire it.
    They reckon you can just wire it straight onto the old horn wires but I figured I'm better off asking around before I get into it.
    Any help is much appreciated
    Edit: I also want to wire it so that it'll work off of the horn buttons on the steering wheel
    Mar 2018
    Perth (near Malaga)
    When I fitted air horns to my motorbike I used the existing horn wiring to drive a relay, and switched a fused feed direct from the battery. I'd do the same thing in the car, much like wiring for driving lights.
    Jun 2019
    Montrose Victoria
    Quote Originally Posted by BradC View Post
    Definitely
    ^^ yep. That’s what I’ve done in the past.
